Topic: is 11/12 an accurate rip? (Read 1992 times) previous topic - next topic
I am very new to ripping CD's to flac. I am ripping my dad's CD collection! :D
So I apologize if following questions are ridiculous :-[
EAC log:
Exact Audio Copy V1.3 from 2. September 2016
EAC extraction logfile from 20. March 2018, 1:07
Indexi / Modra rijeka
Used drive  : TSSTcorpCDDVDW SH-224DB   Adapter: 1  ID: 0
Read mode               : Secure
Utilize accurate stream : Yes
Defeat audio cache      : No
Make use of C2 pointers : No
Read offset correction                      : 6
Overread into Lead-In and Lead-Out          : No
Delete leading and trailing silent blocks   : No
Null samples used in CRC calculations       : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Appended to previous track
Used output format              : User Defined Encoder
Selected bitrate                : 1024 kBit/s
Quality                         : High
Add ID3 tag                     : No
Command line compressor         : C:\Program Files (x86)\Exact Audio Copy\FLAC\FLAC.EXE
Additional command line options : -8 -V -T "TITLE=%title%" -T "ARTIST=%artist%" -T "ALBUMARTIST=%albumartist%" -T "ALBUM=%albumtitle%" -T "DATE=%year%" -T "TRACKNUMBER=%tracknr%" -T "TRACKTOTAL=%numtracks%" -T "GENRE=%genre%" -T "COMMENT=%comment%" -T "PERFORMER=%albuminterpret%" -T "COMPOSER=%composer%" %source% -o %dest%
TOC of the extracted CD
     Track |   Start  |  Length  | Start sector | End sector
        1  |  0:00.00 |  1:01.52 |         0    |     4626
        2  |  1:01.52 |  4:05.43 |      4627    |    23044
        3  |  5:07.20 |  5:00.10 |     23045    |    45554
        4  | 10:07.30 | 11:19.60 |     45555    |    96539
        5  | 21:27.15 |  0:38.30 |     96540    |    99419
        6  | 22:05.45 |  5:52.65 |     99420    |   125884
        7  | 27:58.35 |  4:32.35 |    125885    |   146319
        8  | 32:30.70 |  4:19.12 |    146320    |   165756
        9  | 36:50.07 |  6:52.25 |    165757    |   196681
Track  1
     Filename D:\Indexi - Modra rijeka\01 - Modra rijeka.wav
     Pre-gap length  0:00:02.00
     Peak level 43.2 %
     Extraction speed 2.6 X
     Track quality 100.0 %
     Test CRC F2A29BEC
     Copy CRC F2A29BEC
     Accurately ripped (confidence 2)  [CD52AA9D]  (AR v2)
     Copy OK
Track  2
     Filename D:\Indexi - Modra rijeka\02 - Blago.wav
     Peak level 92.4 %
     Extraction speed 3.0 X
     Test CRC 418CD5A0
     Copy CRC 418CD5A0
     Accurately ripped (confidence 2)  [408A4ECD]  (AR v2)
     Copy OK
Track  3
     Filename D:\Indexi - Modra rijeka\03 - Brod.wav
     Pre-gap length  0:00:01.58
     Peak level 87.9 %
     Extraction speed 3.2 X
     Track quality 99.9 %
     Test CRC 6C0BD00F
     Copy CRC 6C0BD00F
     Accurately ripped (confidence 2)  [2D4315F8]  (AR v2)
     Copy OK
Track  4
     Filename D:\Indexi - Modra rijeka\04 - More.wav
     Pre-gap length  0:00:01.50
     Peak level 92.5 %
     Extraction speed 3.9 X
     Test CRC DA2108CB
     Copy CRC DA2108CB
     Accurately ripped (confidence 2)  [F1972806]  (AR v2)
     Copy OK
Track  5
     Filename D:\Indexi - Modra rijeka\05 - Zapis o zemlji.wav
     Pre-gap length  0:00:00.43
     Peak level 40.0 %
     Extraction speed 3.7 X
     Test CRC A5F17A96
     Copy CRC A5F17A96
     Accurately ripped (confidence 2)  [3C6CA219]  (AR v2)
     Copy OK
Track  6
     Filename D:\Indexi - Modra rijeka\06 - Slovo o čovjeku.wav
     Pre-gap length  0:00:02.15
     Peak level 82.2 %
     Extraction speed 4.3 X
     Test CRC 209CD875
     Copy CRC 209CD875
     Accurately ripped (confidence 2)  [5549BAE5]  (AR v2)
     Copy OK
Track  7
     Filename D:\Indexi - Modra rijeka\07 - Pustinja.wav
     Pre-gap length  0:00:01.53
     Peak level 76.2 %
     Extraction speed 4.7 X
     Test CRC 81BA03A8
     Copy CRC 81BA03A8
     Accurately ripped (confidence 2)  [5288DDED]  (AR v2)
     Copy OK
Track  8
     Filename D:\Indexi - Modra rijeka\08 - More II.wav
     Pre-gap length  0:00:01.55
     Peak level 84.4 %
     Extraction speed 4.8 X
     Test CRC 442B2A4C
     Copy CRC 442B2A4C
     Accurately ripped (confidence 2)  [478BDE72]  (AR v2)
     Copy OK
Track  9
     Filename D:\Indexi - Modra rijeka\09 - Modra rijeka II.wav
     Pre-gap length  0:00:00.60
     Peak level 82.1 %
     Extraction speed 5.0 X
     Test CRC 8EC20FEB
     Copy CRC 8EC20FEB
     Accurately ripped (confidence 2)  [12C02D1B]  (AR v2)
     Copy OK
All tracks accurately ripped
No errors occurred
End of status report
---- CUETools DB Plugin V2.1.6
[CTDB TOCID: LCruN5BpJc8lTt3MPalFEBGXkKo-] found
Submit result: LCruN5BpJc8lTt3MPalFEBGXkKo- has been confirmed
Track | CTDB Status
  1   | (12/12) Accurately ripped
  2   | (12/12) Accurately ripped
  3   | (12/12) Accurately ripped
  4   | (11/12) Accurately ripped
  5   | (11/12) Accurately ripped
  6   | (11/12) Accurately ripped
  7   | (11/12) Accurately ripped
  8   | (11/12) Accurately ripped
  9   | (12/12) Accurately ripped
==== Log checksum DB645947F33E57CDB5ADE120D8009AEFF78EE17A9D76B4B5FF34BE3FDCCF9096 ====
As you can see here some tracks are "(12/12) Accurately ripped" and some are "(11/12) Accurately ripped"
I am not sure what these numbers mean.
I also did a audio checker test:
AUDIOCHECKER v2.0 beta (build 457) - by Dester - opdester@freemail.hu
Started at: Tuesday, 20. 03. 2018. - 1:20.11
9 files found
1 -===- D:\Indexi - Modra rijeka\01 - Modra rijeka.flac
  Extracted successfully
  Conclusion: this track is CDDA with probability 100%
  Tempfile successfully deleted.
2 -===- D:\Indexi - Modra rijeka\02 - Blago.flac
3 -===- D:\Indexi - Modra rijeka\03 - Brod.flac
4 -===- D:\Indexi - Modra rijeka\04 - More.flac
5 -===- D:\Indexi - Modra rijeka\05 - Zapis o zemlji.flac
6 -===- D:\Indexi - Modra rijeka\06 - Slovo o covjeku.flac
  Error while extracting! Check your rights, free some space if needed and ensure the file is valid.
7 -===- D:\Indexi - Modra rijeka\07 - Pustinja.flac
8 -===- D:\Indexi - Modra rijeka\08 - More II.flac
9 -===- D:\Indexi - Modra rijeka\09 - Modra rijeka II.flac
Finished at: Tuesday, 20. 03. 2018. - 1:22.01 (operation time: 0:01.50)
I got an error occurred at track 6. I don't know why...
My questions would be:
- is 11/12 an accurate rip?
and
- if 11/12 is an accurate rip why does the audio checker report an error at track 6 ?
( i also used auCDtect test on the same files and again had an error at track 6 )
Thank you :D
Re: is 11/12 an accurate rip?
Sounds like 11 out of 12 people produced identical rips to yours. And the CRC match means that everyone had the same ripping error on that track. Sounds like it was intentional.
Slightly off topic but shouldn't "Defeat audio cache: No" be set to yes?
I'm still learning about configuration myself so maybe your drive supports this.
Enabling the cache bypass makes ripping very slow. Secure ripping features are largely irrelevant when you can verify the output with AccurateRip. If you had a bad CD that failed to be ripped properly you could enable all re-read options and cache bypassings and try to get better results.
Thank you for clearing this up! I still do not understand why only track 6 had an "error" while other 11/12 tracks did not. I listened to the track itself and it is flawless to my ear.
To my surprise, my CD/DVD drive does not have that option, unlike most drives...
As my CD does not have "Defeat audio cache" feature does that mean that the ripped content is lesser quality? Could this be the reason I got an error at track 6 and no errors in EAC log?
What is it that you think audiochecker does?
Because it tries to check file "06 - Slovo o covjeku.flac" while its real name is "06 - Slovo o čovjeku.flac".
Apparently it doesn't work well with non-ANSI characters.
I have no idea. I think it has got something to do with checking if data is cd quality.
Very nice observation! This may be it!
I just changed č to c in the filename and there were no reported errors. I thought filename did not matter ::)
Started at: Tuesday, 20. 03. 2018. - 23:36.47
1 file found
1 -===- D:\06 - Slovo o covjeku.flac
Finished at: Tuesday, 20. 03. 2018. - 23:37.03 (operation time: 0:00.16)
thanks!
Incidentally, that CDDA probability checker is mostly useless, you can fool it by applying noise shaped dithering to the signal.
