Topic: EAC : File creation error (Read 1131 times) previous topic - next topic
File Creation Error after reading track.
Not sure whats going on but it only happens with two CDs i have here. All other rips are just fine
One disc has odd characters in the filenames, which may be the problem, but the other one hasn't.. So this can't be the case, also the titles not too long.
What could be the cause then?
(See log below)
Exact Audio Copy V1.3 from 2. September 2016
EAC extraction logfile from 13. March 2018, 14:57
Cimbaliband / Moldva
Used drive : HL-DT-STDVDRAM GUE1N Adapter: 1 ID: 0
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : Yes
Make use of C2 pointers : No
Read offset correction : 6
Overread into Lead-In and Lead-Out : No
Delete leading and trailing silent blocks : No
Null samples used in CRC calculations : Yes
Used interface : Native Win32 interface for Win NT & 2000
Gap handling : Appended to previous track
Used output format : User Defined Encoder
Selected bitrate : 1024 kBit/s
Quality : High
Add ID3 tag : No
Command line compressor : C:\flac-1.3.2-win\win64\flac.exe
Additional command line options : -8 -V -T "artist=%artist%" -T "title=%title%" -T "album=%albumtitle%" -T "date=%year%" -T "tracknumber=%tracknr%" -T "genre=%genre%" %source%
TOC of the extracted CD
Track | Start | Length | Start sector | End sector
1 | 0:00.00 | 3:54.64 | 0 | 17613
2 | 3:54.64 | 3:27.44 | 17614 | 33182
3 | 7:22.33 | 4:05.45 | 33183 | 51602
4 | 11:28.03 | 5:10.71 | 51603 | 74923
5 | 16:38.74 | 4:21.66 | 74924 | 94564
6 | 21:00.65 | 3:41.60 | 94565 | 111199
7 | 24:42.50 | 5:59.00 | 111200 | 138124
8 | 30:41.50 | 4:00.57 | 138125 | 156181
9 | 34:42.32 | 4:16.54 | 156182 | 175435
10 | 38:59.11 | 4:20.42 | 175436 | 194977
11 | 43:19.53 | 3:00.38 | 194978 | 208515
12 | 46:20.16 | 2:37.54 | 208516 | 220344
Track 1
Filename D:\EAC\Cimbaliband - Moldva (2015) [FLAC]\01 Mikor kicsi leany votam.wav
Pre-gap length 0:00:02.00
Copy aborted
Track 2
Filename D:\EAC\Cimbaliband - Moldva (2015) [FLAC]\02 Hazam hazam.wav
Copy aborted
1 track(s) not fully ripped for AccurateRip lookup
11 track(s) canceled
No tracks could be verified as accurate
There were errors
End of status report
Log checksum A74F0965A43541908946A044B9E67C8B5B5C87BDDE32E34933305E1A01BA7FF9
Re: EAC : File creation error
Is there "artist" info in each of the EAC track artist fields for those tracks that are causing problems?
jezus.. it was that simple?:) i had to add it manually indeed. it's acting normal now.
thanks a bunch
If it's any consolation, it took me quite awhile to figure it out when I encountered this problem. ;~)
