Topic: Building libFLAC 1.3.2 for iOS (Read 825 times) previous topic - next topic
Hello,
I'd like to integrate FLAC support in an iOS audio app so I need to build libFLAC 1.3.2 for iOS targets, and I've been stuck on that for a while.
I tried to adapt Chris Ballinger's libOpus building script, my build_libflac.sh (curretnly not working) is attached.
I managed to take care of the dependency on libogg by downloading and extracting libogg 1.3.3 and adding --with-ogg=${LIBOGGDIR} option to the configure call.
All 5 compilations run smoothly, but when it comes to the lipo part, I get the following error (I simpliflied the paths with [...] for readibility) :
lipo: [...]/iPhoneOS11.2-armv7.sdk/lib/libFLAC.a and [...]/iPhoneOS11.2-armv7s.sdk/lib/libFLAC.a have the same architectures (x86_64) and can't be in the same fat output file
I tried the lipo command with several couples of built architectures, I get the same error every time: same architectures (x86_64).
If this can be of any information, I get the following output at the end of configure with armv7, armv7s or arm64 :
-=-=-=-=-=-=-=-=-=-= Configuration Complete =-=-=-=-=-=-=-=-=-=-
  Configuration summary :
    FLAC version : ........................ 1.3.2
    Host CPU : ............................ arm
    Host Vendor : ......................... apple
    Host OS : ............................. darwin
    Compiler is GCC : ..................... no
    Compiler is Clang : ................... yes
    SSE optimizations : ................... yes
    Asm optimizations : ................... no
    Ogg/FLAC support : .................... yes
Any idea of how to get libFLAC built for iOS targets armv7, armv7s and arm64 ?
Re: Building libFLAC 1.3.2 for iOS
Have you tried this library from Github? It worked for me a couple of months back when I needed the FLAC library for iOS.
