Topic: Even though CD is on discogs metadata doesn't pull it across (Read 505 times) previous topic - next topic
Hey guys
A few of my discs, although listed on discogs... they don't pull info ove rit just says it can't find the CD on the database but the CD is on discogs on a release page.
Is there a way I can make it search more thorough or is there a way I can input a discogs link into EAC and let it pull that info across?
Re: Even though CD is on discogs metadata doesn't pull it across
Just a particular disc?
Hunch: malformed Discogs entry. Seems to be a quite a few of them in Discogs, from the discussion on the foo_discogs component.
Memento: this is Hydrogenaudio. Do not assume good faith.
aah ok thanks very much for the reply. so can this not really be fixed then? So would i be best off manually filling out all info?
cheers.
What program, component, plugin?
korth
It is EAC latest version. I try using 3 plugins one is GD3. CUETools and builtin. Any ideas what to do next?
If none of the metadata providers can find your CD then you may need to enter manually or use an app like MP3Tag to edit the files and tags after ripping.
The CUETools DB Metadata Plugin only contacts the CUETools DB so it will not search Discogs directly. Metadata is replicated and stored in the CUETools DB from freeDB, MusicBrainz and Discogs.
You could try changing the plugin search mode to 'extensive'.
F12 or EAC > Metadata Options
korth
