Topic: Theme change? (Read 6221 times) previous topic - next topic
Re: Theme change?
Reply #50
I used to be able to search by keyword within a single thread. Now, as far as I can see, it is only possible to narrow the search down to sub-boards. Did I overlook some menu item or command button? If not, is there any plan to restore the functionality or is it a permanent change?
Search by thread is extremely important, I'd dare say vital, for foobies browsing the jscript support thread, to give but one example.
Go the topic that you want to search in first and then define the search term.
The search will display entries from that topic.
Re: Theme change?
Reply #51
Thanks zeremy, but where am I supposed to define the search term? The only search command I can find is the one in the "Community" menu (see attached pic), which leads to the general search settings page.
I'm late
Re: Theme change?
Reply #52
Say you want to search the Topic: JScript Panel script discussion/help
Go to the topic click https://hydrogenaud.io/index.php/topic,110516.0.html and display the topic.
At the top right corner of the page is the search box.
Enter the term to search in the topic.
Re: Theme change?
Reply #54
Alright, I get it now. I was using the "light" variant, changed it to the "be social". Sorry I just learned about this option. I guess I was totally missing the point of the whole discussion thread!  :))
I'm late
Re: Theme change?
Reply #55
So it stays now that left and right is a huge unused space although I have bought extra a wide monitor ?
Thats progress....
Re: Theme change?
Reply #56
Shouldn't the ability to update the engine without massive handcraft be a lil bit higher on requirements priority list of forum software to use?
Re: Theme change?
Reply #57
And which forum are you suggesting I spend weeks migrating to, that isn't going to be a headache some time down the line when a major upgrade comes along?
Re: Theme change?
Reply #58
I didn't have anything particular in mind, sorry. Maybe pull some average of how much your time is worth and invest into some payware? Or revive some kind of donations?
Re: Theme change?
Reply #59
As if any payware forum is any less of a hassle. Unless you were suggesting also hiring someone to handle the migration, and paying someone to keep the theme up to date. I'm sure that would be a great reason to open up donations again, especially since the current system involves me donating my time to maintain this server, with Spoon donating the actual (virtual) server.
