Topic: 1.4 SDK compatibility (Read 2532 times) previous topic - next topic
Maybe this is a dumb question, but if I write my component using the 1.4 SDK, does that mean it will only support v1.4+ of foobar? Is there backward compatibility if I just don't use any of the newer methods?
Re: 1.4 SDK compatibility
It is backward compatible. From SDK changelog:
The SDK is backwards-compatible with foobar2000 v1.3, you can enable v1.4 features without breaking v1.3 compatibility.
The readme doc included with the SDK is pretty comprehensive about this. This SDK produces components compatible with 1.3 unless you specifically edit it to do otherwise.
You can expose 1.4 specific functionality (decoder merit management in particular) without actually requiring version 1.4 or newer.
That said, as a developer, you should test it on 1.3 as well.
I updated the recompiled foo_ac3 and on 1.3.17 that resulted in a missing dll (if I remember the wording correctly). Would that be vcruntime140.dll?
Every single project in the SDK uses statically linked runtime.
If you have a DLL runtime dependency, you must have added it by yourself, or have gotten it from default VS2017 project settings.
Thanks for clarifying, guys. I downloaded the SDK to check out the improved rating.cpp example and stupidly didn't look at the readme.
