Topic: foo_enhanced_playcount - Record all song plays and Last.fm scrobbles (Read 44664 times) previous topic - next topic
Re: foo_enhanced_playcount - Record all song plays and Last.fm scrobbles
Reply #300
Actually the window refreshes after 3 seconds even if the scrobble info for this track remains the same. Maybe if plugin will update scrobble information only if something has changed, than it wil at least romove a big part of a problem.
I believe this should be fixed now in the new version. Try it out and let me know.
Reply #301
Yes, now it is not refreshes after 3 secs for the tracks that have no changes. But of course still does it when track plays to the moment when it updates playcount. I think this Search Window behavior is something, that better to report in the main foobar thread.
Reply #302
I couldn't actually replicate your behavior on 1.6. Search window didn't refresh for me when metadb updates were sent and selection/sorting didn't change at all. Still was a good issue you found, glad it's better at least.
Reply #303
There are different search tools in Foobar. It happens only in Playlist Search window (Edit>Search). Library search does not have such a behavior. Also use 1.6 (Colums UI). Or maybe some specific settings inside Foobar triggers such a behavior.
Reply #304
You're right. I was using Library search. Seeing it now in playlist search. Definitely seems like a foobar issue, especially if it didn't happen before 1.6.
Reply #305
Any way to change play counter moment from 60s to 75% of the track?
In a classic playcounter I set 75% and now both statistics are different
Reply #306
Thank you for this plugin! It seems I can use that and forgo libre.fm scrobbling.
Using 4.3.1 with foo_playcount 3.0.4 and foo_scrobble 1.3.1 (if it matters), and it seems to give surprising numbers for scrobbles (fewer). I checked the API URL manually from the logs, and it gives the correct result.
Querying last.fm: http://ws.audioscrobbler.com/2.0/?method=user.getTrackScrobbles&api_key=<some api key here>&user=ingver&artist=Amon Tobin&track=The Lighthouse&limit=200&format=json&page=1
Found 2 scrobbles in last.fm of "The Lighthouse"
I did try clearing scrobble data for that track and refetching from context menu. Same result.
Strangely the old last fm playcount sync by marc2003 had recorded the correct count. Maybe not as strict with album titles?
The URL in question returns 15, however (see spoiler):
Spoiler (click to show/hide)
Also, as an aside, at some point after first run it started fetching a bunch of scrobbles in quick succession (but still in sequence, not parallel) for lots of my artists, according to logs, until the API key got suspended. Reauthorizing got it working again, so hopefully not an issue. The results were saved to tracks so I guess it was lastfm being strict with rate limits.
Thanks again and sorry if it has been addressed before. Quick search did not yield anything for me.
Reply #307
I understand correctly that there are now two ways to send information about the music being played from foobar2000 to last.fm - using the Audioscrobbler by Florian Heidenreich and using the Enhanced Playback Statistics by MordredKLB? However, I did not find a way to enter my username and password from last.fm in this add-on. Neither the add-on page, nor the add-on help page, nor this thread.
Quote from: foobar2000: Components Repository - Enhanced Playback Statistics
To get the maximum use out of this component, JScript or WSH panel is also required.
I didn't find "JScript" and "WSH panel" in the foobar2000 Components Repository.
Help me please.
Reply #308
Help me please.
It seems some of these components have been not updated for a while. I dug out my old fb2k installation and had to do quite a few changes.
It works for me with a newer https://github.com/gix/foo_scrobble, where you do not have to enter password, but simply oauth flow.
Instead of wsh panel maybe you can try the newer https://www.foobar2000.org/components/view/foo_spider_monkey_panel. I didn't try it myself (since I do not need to display anything except last.fm play count, for which no extra components are needed).
Note that it is not strictly necessary.
wsh panel mode is quite old (https://code.google.com/archive/p/foo-wsh-panel-mod/downloads), it was followed by https://github.com/kbuffington/foo_jscript_panel/releases but it seems a later version is at https://github.com/marc2k3/foo_jscript_panel/releases/tag/v2.4.3. The same author has helped with spider_monkey_panel, it seems.
Reply #309
So it looks like you're maybe playing a track from Splinter Cell soundtrack? There seem to be two scrobbles of that song from that album, while the rest are from a different album. Uncheck "Compare Album field when retrieving scrobbles" and then clear scobbles for that track and repull. At that point it should return 15.
Reply #310
Help me please.
This addon does not scrobble tracks, it just retrieves scrobbles. As ingver recommended, use foo_scrobble.
Reply #311
Hey man thanks for your plugin can you give me a hand please ? I want to skip current track if i scrobbled it on my lastfm, So first step i installed your plugin and filled my username https://imgur.com/a/g78XTk9, Then installed Skip Track plugin and filled the query like %lastfm_play_count% MISSING, But nothing happens when i play something https://imgur.com/a/kjd8f49, Am i missing something ?
Reply #312
2 things:
-you need to fetch playcounts in advance of them being played for it to play nice with foo_skip. You'll need to select all tracks and use the right click menu option to do that.
-you want %lastfm_play_count% PRESENT if you want to skip tracks that you've already played.
Reply #313
@snotlicker It worked thanks!
Reply #314
2 things:
For the most problem free execution, especially immediately after installing the plugin, this answer is correct, but every 12 plays or so the the plugin will pull 1000 old scrobbles (moving backward from the current time), and every 5 tracks it retrieves the 500 most recent scrobbles so it will attempt to keep itself in sync with last.fm, but again you'll have needed to use the plugin for a little bit before it really works perfectly.
