Topic: foobar2000 1.4 beta has been released (Read 140996 times) previous topic - next topic
Re: foobar2000 1.4 beta has been released
REM DATE 1978
REM DISCID 85084809
REM COMMENT "ExactAudioCopy v1.3"
PERFORMER "The Cars"
TITLE "The Cars [UDSACD 2162]"
REM COMPOSER " "
FILE "The Cars - The Cars [UDSACD 2162].flac" WAVE
  TRACK 01 AUDIO
    TITLE "Good Times Roll"
    REM COMPOSER "Ric Ocasek"
    INDEX 01 00:00:00
  TRACK 02 AUDIO
    TITLE "My Best Friend's Girl"
    INDEX 01 03:46:21
  TRACK 03 AUDIO
    TITLE "Just What I Needed"
    INDEX 01 07:30:52
  TRACK 04 AUDIO
    TITLE "I'm In Touch With Your World"
    INDEX 01 11:14:58
  TRACK 05 AUDIO
    TITLE "Don't Cha Stop"
    INDEX 00 14:45:69
    INDEX 01 14:47:04
  TRACK 06 AUDIO
    TITLE "You're All I've Got Tonight"
    INDEX 01 17:50:67
  TRACK 07 AUDIO
    TITLE "Bye Bye Love"
    INDEX 01 22:05:02
  TRACK 08 AUDIO
    TITLE "Moving In Stereo"
    REM COMPOSER "Ric Ocasek;Greg Hawkes"
    INDEX 01 26:17:73
  TRACK 09 AUDIO
    TITLE "All Mixed Up"
    INDEX 01 31:02:33
Removed REM from composer but then the CUE didn't read.
EZ CD Audio Converter / FLAC or WavPack
"REM COMPOSER" is valid.  "COMPOSER" is not.  "REM" is a comment, remark, or something that's to be ignored by the burning application itself.  The reason it fails to load after "REM" is removed is that's no longer a valid cuesheet.
You can change "REM COMPOSER" to "SONGWRITER" and the cuesheet will still load, but foobar2000 won't map it to composer.
"PERFORMER" is treated the same as track artist (or album artist if it's before the album title) by foobar2000 when it's reading cuesheets.  It will always show the track artist if the field is filled in.  A workaround is put the composer in the artist field but if this already filled, it may require some re-wording of the value itself.
How foobar2000 shows "artist" metadata by default ">" means that the field before it is empty so it goes to the next one.
Normal file: Track Artist > Album Artist > Composer > Performer > ?
Cuesheet: Track Performer > Album Performer > ?
foobar2000 v1.4 final is now available.
I just updated and noticed that the option to edit the cue sheet (Rightclick -> Utilities -> Edit Cue Sheet) is gone. Can you tell me if there is another way to embed a Cue Sheet now?
This thread will show how to find the feature.
Reply #30
Thank you very much!  :)
I updated one of my components, foo_openmpt54, to use dynamic runtime, but the latest 1.4 is missing two runtime files that this plugin will require: vcruntime140.dll and msvcp140.dll.
The standard install leaves away unnecessary runtime files if equal or newer ones are already installed on the system.
Reply #33
Oh. Oops.
Reply #34
How to get a request to the developer of the SACD and DSD Processor plug ins for Foobar2000?
Reply #35
The SACD plugin has a SourceForge issue tracker, although I'm not sure if it's the best place for requests.
