Topic: Fade-in/out DSP (Read 3534 times) previous topic - next topic
Fade-in/out DSP
I'm looking for simple fade-in/fade-out (not crossfade!) DSP, with customizable fading length. Is there such plugin?
Re: Fade-in/out DSP
Fake Gapless DSP is a simple cosine fade, but as it was meant for fixing lossy encoding glitching its config allows only 10 ms fades at max. If you need longer I could make a version with no such limit.
Re: Fade-in/out DSP
Does it do both fade in and out?
If so, it is almost what I'm looking for.
Please, if you can.
Re: Fade-in/out DSP
Took a bit longer than I anticipated. But version 1.0 of Fade In/Out DSP is ready.
Re: Fade-in/out DSP
Great! Thank you!
Re: Fade-in/out DSP
An option to not trigger when the track starts from the beginning or ends at the ending would be awesome. Though that might be beyond the capabilities of DSP.
Re: Fade-in/out DSP
What do you mean exactly? To have an option to not apply fade-in to the first played track and no fade-out to the last played track? Such a thing would be possible to achieve for realtime playback but it wouldn't work with Converter. Or did you mean something else?
Re: Fade-in/out DSP
What I meant was not to apply it when any "natural" starts/stops occur within the playlist. I.E.:
1. The track starts playing from the beginning when 'play' is pressed (not form a paused state)
2. The track ends because its playtime runs out
3. Next track in the playlist/queue starts autoplaying from the beginning
So, the fadein/out would only trigger when you press stop, pause, or resume paused track
Hope that's more comprehensible
Re: Fade-in/out DSP
Hope this helps:
From the wiki
Fading
This section appears when a DirectSound device is selected.
Without fading, transitions can be jarring when jumping from one track to the next, or when seeking within a track. This section allows this effect to be softened.
The sliders adjust the fade in and fade out values or the currently selected type of fade (pause & stop, seek within a track, manual track change, automatic track change). Arrow keys may allow the sliders to be adjusted with greater precision than a mouse or touch surface.
Re: Fade-in/out DSP
Yeah, thanks for the heads up. Unfortunately that is Directsound only.
Re: Fade-in/out DSP
Very useful plugin. Thank you.
Re: Fade-in/out DSP
HI,
I'm trying this but while works great in playback, during convert process, stop working after about 8 songs (I think that because of cpu core used). so if I convert 40 songs, just the first are with fade out and others no.
Thank you for your help.
Aldo
Re: Fade-in/out DSP
Thanks for the report. Fixed version has been uploaded.
