Topic: Java FLAC encoder compression better than flac.exe 1.3.2 level 8 (Read 3687 times) previous topic - next topic
I am using this cool Java lib to stream audio in FLAC format. I noticed that with a single sample it compresses better than "flac.exe -8" around 3.5%. Surely I must be doing something wrong but I cannot see what? I am linking the flac file compressed with javaFlacEncoder. The file is stripped from tags.
http://javaflacencoder.sourceforge.net
http://stigc.dk/javaflacencode.flac
Flac.exe commandline
flac.exe -8 javaflacencode.flac --output-name flac1.3.2encode.flac
Re: Java FLAC encoder compression better than flac.exe 1.3.2 level 8
There's actually a higher compression setting for flac: -8e. It reduces the difference to a few kilobytes, which is probably just the file format or tags or something like that.
Quote from: http://javaflacencoder.sourceforge.net
File sizes comparable to flac reference encoder, typically <5% difference.
Thanks, that helped a lot.
flac.exe -8e javaflacencode.flac --output-name flac1.3.2encode.flac
2177 KB flac1.3.2encode.flac
2169 KB javaflacencode.flac
Still funny that the Java implementation is 8Kb smaller ~ 0,3%
If i encode the whole file (the link is only a portion of it) I see a greater difference.
4822 KB flac1.3.2encode.flac
4739 KB javaflacencode.flac
FLAC 1.3.2 creates a 1,75% larger file that the java implementation, which is quite a bit.
I have bit-compared the files and the output is the same.
Personally, I'd call that insignificant.     For example, I wouldn't choose ALAC over FLAC (or vice-versa) just to get a 2% smaller file...   There are other considerations when choosing a format.  I wouldn't re-encode my entire music library to save 2% if there was a "newer-better" version of FLAC...  It's just not that important to me.    It would only be a problem if you are very-very tight on memory/storage.
If I gave you two weighs and one was 2% heavier or lighter than the other, do you think you could feel the difference?  If I showed you a length of rope and then showed you another an hour later do you think you could tell which one was 2% longer/shorter?  Would you wait a week to buy something to save 2%?   (OK, you might wait a week to save 2% on a car or house but you probably wouldn't walk across the street to save 2% on a cup of coffee.)
The same or smaller?  Can't have it both ways.  What is smaller and what bit-matches exactly?
This is a tiny difference, but enough that it should either be accounted for by metadata, some non-default flac parameters, or would be desirable to incorporate (assuming it is always an improvement and not just random variation).
I think it's pretty clear that what stigc meant is that the decoded output was identical while the encoded version was smaller. If the output wasn't identical then the discussion would be something else entirely.
I would also agree that 1.75% is pretty significant, especially if that's referenced to the original file size (not the compressed size). Isn't that bigger than the difference between FLAC -5 and FLAC -8? If someone produced a WavPack file that showed that improvement I would fall out of my chair. Even if it's "random variation" it could be an interesting avenue to improvement.
What is possible (and probably likely) is that there is something "weird" about this file that happens to trigger this, and the vast majority of regular files will not show this. Then it becomes much less interesting.
Byrant, I think you're right. I encoded the whole album, and only this songs compresses better with the Java implementation. Also i tried flake.exe that did a even better job
4671 KB flake.flac
I also noticed that the reference encoder (flac.exe) uses fixed block size, maybe this is the real explanation?
https://xiph.org/flac/format.html#architecture
Right again, I should compare with the original size
flac.exe 16125 4822 0,299038759689922
java         16125 4739 0,293891472868217
flake.exe 16125 4671 0,289674418604651
The thing I notice is the < 30% compression ratio, which is already a little weird.
If that's the only track that compresses that much (whether it's really quiet or has periods of silence) then the reason is probably related to that (and could be related to block size).
-8e, is that a good option?  And I don't think the -e and -p are related to tags ...?
Anyway, I get the following with flac 1.3.2 (Windows, downloaded from xiph):
2 221 407 bytes using flac.exe -8 -p -e
2 221 363 bytes using flac.exe -8 -p -e --nopadding
2 220 416 bytes for the javaencode download.
Using metaflac --dontusepadding --remove-all, the javaencode is reduced to 2220 372 and the smallest of the flac.exe's from 363 to 225.  Not much explanation there, but the filesize difference is then down to 843 bytes.
No. Both files (edit: the java encoded and the smallest flac.exe encoded ... presumably all, but I haven't checked) use blocksize of 4096, except the last (2188).
Edit: --remove-all removes both SEEKTABLE and APPLICATION, right?
2.220.416 Bytes for javaencode
2.168.449 Bytes for CUEtools flake 2.16 -8 (is 4096 blocksize default. Old flake may be non standard)
