Topic: Ogg conversion from .WEM files (Read 11845 times) previous topic - next topic
Trying to extract sound files from Witcher 3. I used quick bms to unpack the sound cache files, which resulted in a bunch of bnk and wem files. I managed to convert the bnk files in ogg using wwise unpacker, then used a standard audio converter (Pazera) to convert from ogg to wav. I tried the same with the wem files, even followed https://forum.xentax.com/viewtopic.php?f=17&t=7792&start=15 instructions (https://imgur.com/a/25lSD), but the cmd process stops after a couple of lines and no ogg files were created (https://imgur.com/a/5QyS9). Do these wem files have a specific type of encrypting like the bnk ones? And if so, what can i do to convert them?
Re: Ogg conversion from .WEM files
Google is your friend:
How about these instructions?
Listen to the music, not the media it's on.
Musepack --quality 6
Wavpack -hb4.55x5cvm
I think ww2ogg is what you need.
I swear you should be able to do this with ffmpeg but perhaps it is beyond even the program that can play anything.
VGMStream now has native support for WEM archives, so you don't even need to convert them to Ogg files to play them.
