Topic: Lame 3.100 has been released (Read 60483 times) previous topic - next topic
Re: Lame 3.100 has been released
Reply #75
Your parameters are wrong. The right parameter for CBR is --cbr. The data gets treated as RAW PCM and it's assumed to be 16 bits.
Reply #76
I just did a little test with the most recent SVN code. It compiles smoothly and fast but the encoding speed is terribly low, about x7(default settings) vs x27 with lame 3.95.
Am I missing something?
Reply #77
Figured it out, gcc optimization flags are missing after recent compiler detection change. Latest lame cannot really be compiled with gcc.
Reply #78
LAME development is culminated. Last quality changes were made 6 years ago.
In the other hand LAME developers have squeezed all out of what MP3 can do.
Thank You for release.
:) life continues ...
Couldn't have said it better...
Reply #79
Yeah, LAME has definitely reached its pinnacle ever since.
The finest MP3, as a format, will ever be.
Listen to the music, not the media.
Reply #80
Not according to some ABX. Also, it's extremely slow.
Reply #81
I meant in terms of what LAME could milk, quality-wise, out of the MP3 format itself; as the problem samples detectable during ABX'ing seem to be inherent to that format.
Reply #82
hi everybody, anyone knows how can i pass the dB value computed with the --replaygain-accurate switch into the new --gain switch?
Reply #83
i may be the sole user of lamedrop (xpd), but was wondering if you'd be able to update that too at some point?
+1
You are not alone :)
Reply #84
As an example, the output was ReplayGain: -8.3dB then add --gain -8.3 to your command line.
Reply #85
yes that is simple and even i managed to realize it. :)
but there is a way to do something like
lame -V 0 -S --gain $(--replaygain-accurate ) inputfile outputfile
just to encode with the right volume in one passage ?
Reply #87
+1
LamedropXPd updated compiles are now on Rarewares. Sorry for the delay. ;)
John
My compiles and utilities are at http://www.rarewares.org/
Reply #88
Thanks a lot! :)
A small glitch: even though the About window says "Using LAME 3.100.0" the Encoding Options window says "Using LAME 3.99.5 encoding engine".
Reply #89
Ooops!! That's only narrative, it was compiled using 3.100, but I'll make the change and upload again. Thanks for the 'heads up'. ;)
John
Reply #90
New LamedropXPd compiles uploaded with the narrative corrected. :)
John
Reply #92
Here my tests:
Chocobo1 (msvc2017, nasm 2.13.01)
32bit - 68x
64bit - 58x
Files produced: same
Descrates (all are 32bits)
tmkk patch + clang 5.0 + icl 15 + msvc2010 lib + icl 15 lib - 76x
clang 5.0 with msvc2010 lib - 65x
msvc2005 - 47x
Files produced: same for clang versions, msvc2005 different than clang
Tmkk (gcc-5.4/MinGW)
32bit - 79x
64bit - 79x
Rarewares (Intel Compiler)
32bit - 60x
64bit - 75x
Files produced: different, comparing says one of them produces 3 clicks at the beggining. Otherwise they null.
Foobar2000 (no compiler info)
32bit - 64x
Looks like Rarewares build is fastest without patches. But the problem is 32bit & 64bit versions don't null and three pops appear in beggining of one of the files (when null compared). I have no idea why if they use same Intel Compiler.
Maybe it should be recompiled again?
Reply #93
If there is any assembly in a program, and you aren't disabling assembly, then the 32 and 64 bit versions won't be running the same code paths. For this reason you shouldn't expect the results to be identical.
Reply #95
I've re-compiled and uploaded the lame bundles. The 32 bit version appears unchanged, but there is a difference with the 64 bit version. Personally, I can't hear a difference, but maybe someone can do a more exhaustive check. :)
John
Reply #96
Here too, much faster: http://tmkk.undo.jp/lame/index_e.html
with this patch applied, i get an error when i try compile x86
./configure  --host=i686-w64-mingw32 --enable-shared --enable-static
and then "make -j2" leads to a
gain_analysis.c: In Funktion »filterYule«:
gain_analysis.c:216:5: error: impossible constraint in 'asm'
     __asm__ __volatile__ (
sorry i was wrong, it does work, i simply made a silly mistake. :(
Hello, how your fix this error? Thank you in advance.
Reply #97
pretty easy... SSE2 (-msse2) is mandatory to compile this patched version.
Reply #98
how will look the command for configuration and compilation?
Reply #99
tmkk patch + clang 6.0 + msvc2010 lib + icl 16 lib
nothing special, GOGO-no-coda ~256kbps VBR + mp3packer
