Re: Biography Text, Album Info, Picture. www.last.fm Reply #75 – 2019-02-23 13:01:33 Hello,kgena_ua,I have used the newest script. Could you please make some changes for more better?1)one special character,like dot ".". It can not be changed to dot"."(keep the same).2)It can not set the path of the album's images in one seperate directory.(named as %album artist% - %album%)3) I don't need some information for XXX_the _artist_info.ini.(except:external_links,born)I wish you make this to be the one best excellent script tool. Thank you very much. Last Edit: 2019-02-23 13:04:49 by hikaze
Re: Biography Text, Album Info, Picture. www.last.fm Reply #76 – 2019-02-24 02:49:49 And 4) if the search information is empty,don't create this artist's folder.(add a property like as setting: "remap artist").Thanks.
Re: Biography Text, Album Info, Picture. www.last.fm Reply #77 – 2019-02-24 05:45:51 Hello, I found that "remap artist" and "Unkown Artist"(no information) can be one function.(Add a fuction button "remap"- "remap to Unkown Artist and delete the folder"(like black list)). By the way,some artists have no other language's translation.(like as no information)(It will be much better to fetch the correct language information automatily.) Last Edit: 2019-02-24 05:49:24 by hikaze
Re: Biography Text, Album Info, Picture. www.last.fm Reply #78 – 2019-03-30 19:33:38 hikaze,I will think
Re: Biography Text, Album Info, Picture. www.last.fm Reply #79 – 2019-04-08 16:25:47 Hi there!@kgena_ua, Please add the lock mode with the "lock" button on the script field window. Because sometimes a song ends (image and text change) before you have time to read the text and view the images (for example when listening to internet radio).It would also be nice to add a mode of fixed separation of text and image excluding overlay.Thanks for this great script! Last Edit: 2019-04-08 17:18:45 by Sergey77
Re: Biography Text, Album Info, Picture. www.last.fm Reply #80 – 2019-04-18 09:43:36 Quote from: Sergey77 on 2019-04-08 16:25:47Hi there!@kgena_ua, Please add the lock mode with the "lock" button on the script field window. Because sometimes a song ends (image and text change) before you have time to read the text and view the images (for example when listening to internet radio).Very interesting.As you see it. Menu item, hotkey or something else. How to call this feature. How should this work.
Re: Biography Text, Album Info, Picture. www.last.fm Reply #81 – 2019-04-18 16:55:50 Conveniently if it would be the "Lock" button as shown at the picture (highlighted in red).If the user clicks on the "Lock" button, mode is on - when the music track and the artist change, but the picture and text do not change, they remain for the previous track and artist.If the user clicks on the "Lock" button again, mode is off and the script continues to work as usual.Thank you! Last Edit: 2019-04-18 17:27:33 by Sergey77
Re: Biography Text, Album Info, Picture. www.last.fm Reply #82 – 2019-04-20 15:18:27 Hello,This script took a long time to load.(more than 8s, sometimes > 30s).(Some reason is that I used 2 script in Panel.)I think this script need to speed up the load speed.It used too many function clean(). Sorry,I don't much more ability to improve with it. I'm a new learner.208 line:(The special characters do not need to be customized.I think that another plugins also handled it simply.) var tmp = n.replace(/[\/\:\*\?\"<>\|\\]/g,"_"); Last Edit: 2019-04-20 15:20:50 by hikaze
Re: Biography Text, Album Info, Picture. www.last.fm Reply #83 – 2019-06-27 17:56:45 "Biography, albums, title, similar artist info.www.last.fm."@version "27062019"jscript panel, wsh panel mod.Add:- new customizable main menu - see menu item "Main menu setting";- lock mode - left mouse button dblclk on header_1 (artist);- collapse / expand additional info text - popup button between header_2 and main text;- menu item "Hisory" - view previously downloaded data if it is stored in the tmp_Biography folder (by default).Saved data reload.Before installation, clear variables - the "Properties" menu. Last Edit: 2019-06-27 18:03:57 by kgena_ua
Re: Biography Text, Album Info, Picture. www.last.fm Reply #84 – 2019-07-05 21:45:10 Hi! Last.fm again changed the design ... Every time it gets worse! And the photos stopped loading ...
Re: Biography Text, Album Info, Picture. www.last.fm Reply #85 – 2019-07-07 13:38:40 Quote from: udege on 2019-07-05 21:45:10Hi! Last.fm again changed the design ... Every time it gets worse! And the photos stopped loading ...udege,new test version you can find herehttp://foobar2000.ru/forum/viewtopic.php?t=1878&p=73458#p73458 Last Edit: 2019-07-07 14:20:27 by kgena_ua
Re: Biography Text, Album Info, Picture. www.last.fm Reply #86 – 2019-07-09 16:10:19 No update? Still "No Photo" in Biografi.
Re: Biography Text, Album Info, Picture. www.last.fm Reply #87 – 2019-07-10 14:08:35 Quote from: emaulana on 2019-07-09 16:10:19No update? Still "No Photo" in Biografi.emaulana, see previous post
Re: Biography Text, Album Info, Picture. www.last.fm Reply #88 – 2019-07-10 14:33:38 hi kgne_uaI'm using your script from 20180324 (JScript1.3.2.2) - any chance to update this too?does your newest script have the option to disable some information?i only want to see the artist-name and the biography; all other information in between is useless information for methanks
Re: Biography Text, Album Info, Picture. www.last.fm Reply #89 – 2019-07-10 14:48:59 Quote from: kgena_ua on 2019-07-10 14:08:35Quote from: emaulana on 2019-07-09 16:10:19No update? Still "No Photo" in Biografi.emaulana, see previous postOk, it is working now. Thank u for your script bro. My Foobar2000 is look beautiful again.
Re: Biography Text, Album Info, Picture. www.last.fm Reply #90 – 2019-07-10 19:41:59 @kgena_uasorry, I didn't read your mail well enough. the function is already inside.thank you
Re: Biography Text, Album Info, Picture. www.last.fm Reply #91 – 2019-07-13 17:46:53 "Biography, albums, title, similar artist info.www.last.fm."@version "13072019"Minor fixes."External links" work.Added the ability to view text using the keys UP, DOWN, PAGE_UP, PAGE_DOWN, HOME, END.LEFT and RIGHT keys to change the image.Accordingly, the panel should be active (selected, left-click on the panel, for example).
Re: Biography Text, Album Info, Picture. www.last.fm Reply #92 – 2019-07-13 20:06:02 hi kgena_uaworks perfect - great work !!
Re: Biography Text, Album Info, Picture. www.last.fm Reply #93 – 2019-07-14 11:06:51 Great script. Thanks for making this.
Re: Biography Text, Album Info, Picture. www.last.fm Reply #94 – 2019-09-01 12:15:52 "Biography, albums, title, similar artist info.www.last.fm."version "24082019"Changes in the history menu section:- history list navigation - Mouse, Up, Down, Page Up, Page Down, End, Home keys;- artist selection - left mouse button, Enter key;- deleting a list item - menu, Delete key;- delete history list - menu.Minor changes and improvements.Properties needs to be updated.
Re: Biography Text, Album Info, Picture. www.last.fm Reply #95 – 2019-09-05 20:41:07 need your recommendations for improvements
Re: Biography Text, Album Info, Picture. www.last.fm Reply #96 – 2019-10-19 17:21:07 Looks like the pulling of artist art is broken? It won't load artist art anymore for me.
Re: Biography Text, Album Info, Picture. www.last.fm Reply #97 – 2019-10-22 16:22:49 I confirm.images are no longer loaded.Last.fm has changed its site.version 24.08.2019 Last Edit: 2019-10-22 16:55:45 by lender1257
Re: Biography Text, Album Info, Picture. www.last.fm Reply #98 – 2019-10-28 04:21:22 @kgena_ua new version 2019-10-26 works - thank youhttp://foobar2000.ru/forum/viewtopic.php?t=1878&start=2660
Re: Biography Text, Album Info, Picture. www.last.fm Reply #99 – 2019-11-07 13:00:16 "Biography, albums, title, similar artist info.www.last.fm."version "07112019"compatible with WSH panel mod and jscript panellender1257,what is your opinion about the versions 26102019 and 07112019 Last Edit: 2019-11-07 13:04:14 by kgena_ua
