Topic: iOS not correctly mapping multichannel audio files unless "no channel layout" (Read 7172 times) previous topic - next topic
iOS not correctly mapping multichannel audio files unless "no channel layout", for example:
Does map correctly:
afinfo "6_Channel_ID_10sec_NoLayout.wav"
File:           6_Channel_ID_10sec_NoLayout.wav
File type ID:   WAVE
Num Tracks:     1
Data format:     6 ch,  44100 Hz, 'lpcm' (0x0000000C) 16-bit little-endian signed integer
                no channel layout.
Does NOT map correctly:
afinfo "6_Channel_ID_10sec.wav"
File:           6_Channel_ID_10sec.wav
File type ID:   WAVE
Num Tracks:     1
Channel layout: 5.1 (L R C LFE Ls Rs)
When either of these input .wav files are encoded to AAC using afconvert, the output .m4a will always have channel layout assigned, and will not map correctly.
How to encode files to AAC (or modify the Packet Table Header?) to produce multichannel AAC files that will report "no channel layout" to afinfo, and therefore presumably map correctly?
