Topic: Wich are the optimal encoding settings for each lossless encoder? (Read 4717 times) previous topic - next topic
Hello, guys.
Recently I have performed the comparison of 11 best / most popular lossless encoders where I used the (almost reasonable) maximum compression settings. But I understand that in reality it's results aren't so useful, because maximum compression settings are used too rarely. So I'm planning to complete the test with optimal settings, which could be / are used for sharing (torrent trackers, file-sharing services, etc.)
The problem is - how to find out which settings are optimal? Some time ago I made the detailed analysis for FLAC 1.2.1:
But it took much time - to encode/decode in every mode.
I thought: maybe there are some generally accepted modes for every encoder or there are some tests already, so I don't need to reinvent the wheel?
Will be thankful for any help.
Re: Wich are the optimal encoding settings for each lossless encoder?
Thank you, Igor, that's it!
