Topic: Cannot write with EAC with external devices. (Read 341 times) previous topic - next topic
Hi. I have a Samsung SE-208DB MF00 external device and I can’t write with EAC.
When trying to write without CDRDAO, EAC does not, and shows the window of the screenshot “eac writing problems_2” attached image file.
When trying to write with CDRDAO, EAC does not, and shows the window of the screenshot “eac writing problems_1” attached image file.
I search in internet for solutions, finded three similar cases.
I copied the cdrdao.exe and Cygwin.dll from CDRDAO folder to Eac’s folder and wn32.dll to CDRDAO folder.
I tested changing and adding values to Cygwin’s key in Registry
By the way, I downloaded Cygwin enviroment cause I’m trying to compile CDRDAO and GCDMaster, but unfortunately I have few clues to do it actually.
Every test was done one  by each time and later, keeping changed things in they original status.
Nothing I mentioned above solve the problem; same happens with a Liteon Ps3 Wii external device have.
Everything works fine with Nero.
I’d be thankful for any clue, idea…
Thanks in advance.
ampyx
Re: Cannot write with EAC with external devices.
OK, why not Nero or any other burning application?
...I've only used EAC for ripping.   I never though about using it as a burner.
