Topic: qaac.exe vs. iTunes Plus AAC Preset Encoding (Read 6007 times) previous topic - next topic
Hello,
I currently encode and backup my music files to FLAC.
I then convert those files to ALAC and drop them into iTunes.  I then use iTunes to convert the files to AAC using the iTunes Plus preset for my iPod.
Would converting the FLAC files directly to AAC TVBR with a quality at around 256 using the qaac.exe extension create almost identical files?  It would save me a few steps and some time in the conversion process.
I did a test and tried to ABX 2 different tracks (electronic music with some crazy sounds) and I got 5/10 and 6/10... So, not very convincing.
While conducting the test, I could tell a small difference between the two tracks when flipping back and forth, but I couldn't replicate it from track to track...
Has anyone else tested this or have any experience?
JXL
Re: qaac.exe vs. iTunes Plus AAC Preset Encoding
The small difference could come from the use of smart padding. Qaac enables smart padding as a default setting. If you want you can disable smart padding with the --no-smart-padding option. This should achieve bit-identical result as iTunes (quotet from the qaac encoder configuration page)
Thank you for replying.  I will try it with the --no-smart-padding option later tonight. :)
JXL
Ran some tests last night and have to say that I now am in love with qaac.exe.
I tested a bunch of tracks and am going to leave the smart padding option enabled.  It fixed the playback on a few discs that my iPod would get stuck when transitioning from one track to the next of a gapless album.  It's one of those 50 track DJ mix albums with lots of short/edited tracks with fast transitions.  It works like a charm now though. :)
JXL
