Topic: 24bit files not to convert to another format (Read 3545 times) previous topic - next topic
Hello.
I can not convert 24bit files to another format. Can i adjust it somehow?
greeting
jürgen
Re: 24bit files not to convert to another format
What is the target format and what operating system are you using?
Hi
24bit Flac and other 24bit and hi-res files...
it comes the covert-window and writes 0 byte mp3's, when i will convert to mp3.
i have no plan whats going wrong.
jürgen
Hello.
greeting
jürgen
What software are using to attempt the conversion with?
Audacity?
no.. with foobar
now i see...
sorry and thanks
24bit should not be the problem.
However Mp3 does not support samplerates higher than 48khz, so i would suggest using a resampler DSP and convert it to 44.1khz (or 48khz).
You can be lazy and convert it to ALAC 24 bit...   Then add the ALAC 24 bit file to iTunes and convert that to your codec of choice.
I use the iTunes Plus AAC preset and it resamples the 24/96 down 16 bit 44.1khz AAC with TVBR.
JXL
