Topic: fb2k v1.3.16 app crashes intermittently (Read 1151 times) previous topic - next topic
fb2k crashes intermittently. downgraded back to v 1.3.15 and all is good.
Faulting application name: foobar2000.exe, version: 1.3.16.0, time stamp: 0x59630f77
Faulting module name: ntdll.dll, version: 10.0.15063.447, time stamp: 0xd51d5c5e
Exception code: 0xc0000005
Fault offset: 0x0005da74
Faulting process id: 0x17b0
Faulting application start time: 0x01d30780b1851823
Faulting application path: C:\Program Files (x86)\foobar2000\foobar2000.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: 5f4865eb-9879-426b-9cc5-744249024819
Faulting package full name:
Faulting package-relative application ID:
Re: fb2k v1.3.16 app crashes intermittently
It never crashes in a way that foobar2000 catches it and shows you a dialog to submit crash details?
Can you reproduce the crash with a clean portable installation without third party components?
If you can, hearing more details about the hardware might be helpful.
If you can't, it's very likely one of the components you have installed has a problem. If there are never component names mentioned in the crash log and foobar2000 can't submit a memory dump, the only way to track it is to remove components until the crashing stops.
Thank you.
I found the culprit - "Oscilloscope (Direct2D)"
Once removed, no more crashes.
