Re: Opus 1.2 is out! Reply #50 – 2017-07-06 15:30:08 hijust downloaded opus 1.2 from the homepage , and i want to upgrade my encoderdo I need only opusenc.exe or libopus-0.dll & libopusfile-0.dll too?thanks for the new update
Re: Opus 1.2 is out! Reply #51 – 2017-07-08 17:54:39 francescoJust use any of 1.2.1 binaries posted in this topic. https://hydrogenaud.io/index.php/topic,114234.msg941208.html#msg941208https://hydrogenaud.io/index.php/topic,114234.msg941283.html#msg941283https://hydrogenaud.io/index.php/topic,114234.msg941312.html#msg941312https://hydrogenaud.io/index.php/topic,114234.msg941462.html#msg941462https://people.xiph.org/~jm/opus/opus-1.2/Comparing Opus to MP3 only? When Opus has outperformed LC-AAC, HE-AAC, Vorbis at 64-96 kbps. I have also tested Opus 1.2 alpha vs state of the art HE-AACv2 encoder ( ~32 kbps, VBR, FhG) . https://hydrogenaud.io/index.php/topic,111798.msg930611.html#msg930611Opus 1.2 alpha was already better than HE-AACv2 at 32 kbps in my test and 1.2 release contained quality improvements too comparing to alpha/beta.You can throw in comparison with Opus literally any available codec. Last Edit: 2017-07-08 17:56:40 by IgorC
Re: Opus 1.2 is out! Reply #52 – 2017-07-09 04:58:46 Quote from: IgorC on 2017-07-08 17:54:39francescoJust use any of 1.2.1 binaries posted in this topic. Hi @IgorC thanks IgorC
Re: Opus 1.2 is out! Reply #53 – 2017-07-10 12:28:20 What happened to the official FLAC support on the Mozilla builds? Was working fine on opus-tools-0.1.9-win32 and then poof, it's gone. I tried both opus-tools-0.1.10-win32 and ...-win64Code: [Select]Error parsing input file: song.flacI did notice the 3rd party compiles by users of the forums, Was curious of the official status.
Re: Opus 1.2 is out! Reply #54 – 2017-07-11 14:48:17 The CI of the MSVC projects doesn't include FLAC, that's just it.
Re: Opus 1.2 is out! Reply #55 – 2017-07-13 09:15:49 Given the quality improvements (which are great!), shouldn’t the Opus line be moved (or tilted) up accordingly here:
Re: Opus 1.2 is out! Reply #56 – 2017-07-13 10:21:31 Quote from: bandpass on 2017-07-13 09:15:49Given the quality improvements (which are great!), shouldn’t the Opus line be moved (or tilted) up accordingly here:You're right, I noticed the same some time ago. Now fullband is being supported down to 14 kbps.
Re: Opus 1.2 is out! Reply #58 – 2017-09-04 01:06:49 Quote from: niga_in_da_block on 2017-09-04 00:01:14Why no AAC <40 kbps on this graph?Has anyone actually done that comparison with Opus?
Re: Opus 1.2 is out! Reply #59 – 2017-09-04 01:54:28 Quote from: saratoga on 2017-09-04 01:06:49Quote from: niga_in_da_block on 2017-09-04 00:01:14Why no AAC <40 kbps on this graph?Has anyone actually done that comparison with Opus?Here is somethinghttps://hydrogenaud.io/index.php/topic,114370.0.htmlhttps://hydrogenaud.io/index.php/topic,114234.msg941691.html#msg941691but it's just one person
Re: Opus 1.2 is out! Reply #60 – 2017-09-04 16:48:57 Quote from: bandpass on 2017-07-13 09:15:49Given the quality improvements (which are great!), shouldn’t the Opus line be moved (or tilted) up accordingly here:Yes, and move down the MP3 128kbps a tiny bit, to the quality of Vorbis 96kbps.This is according to the 2014 public multiformat listening test.
Re: Opus 1.2 is out! Reply #61 – 2017-09-07 08:00:01 Quote from: ziemek.z on 2017-07-13 10:21:31Quote from: bandpass on 2017-07-13 09:15:49Given the quality improvements (which are great!), shouldn’t the Opus line be moved (or tilted) up accordingly here:You're right, I noticed the same some time ago. Now fullband is being supported down to 14 kbps.Someone should re-do the graph and make it really, really crude. Like with pencil on the inside cardboard of a cereal box or something. Couple mistakes and also use an eraser each time something makes.My thinking is, this would epitomize the approximate nature of the graph. Bonus points for fitting the entire graph inside a 8x8cm box, and use crayons to draw the lines.
Re: Opus 1.2 is out! Reply #62 – 2017-09-11 17:17:35 Quote from: polemon on 2017-09-07 08:00:01Someone should re-do the graph and make it really, really crude. Like with pencil on the inside cardboard of a cereal box or something. Couple mistakes and also use an eraser each time something makes.My thinking is, this would epitomize the approximate nature of the graph. Bonus points for fitting the entire graph inside a 8x8cm box, and use crayons to draw the lines.Actually, that figure started off pretty much like what you're describing when presented at an IETF meeting (see slide 15).
Re: Opus 1.2 is out! Reply #63 – 2017-09-12 09:55:29 Quote from: jmvalin on 2017-09-11 17:17:35Actually, that figure started off pretty much like what you're describing when presented at an IETF meeting (see slide 15). Yeah, that's pretty much what I kinda thought of. Although a part of me wants to make this diagram a bit more complete, and update it with things like patents that have expired, like G.729.That, and adding "unfinished" or "experimental" codecs, like Codec2.
Re: Opus 1.2 is out! Reply #64 – 2017-09-12 22:15:27 My improvement idea (work in progress)Opus tilted upMP3 tilted down around the 128kbps areaAAC extended to 32 kbpsColor altered for color blind friendlinessLegend color area enlarged for color blind friendlinessSVG source code cosmetics for better readability and smaller sizeOriginal: https://opus-codec.org/static/comparison/quality.svgMy rework: https://ss1.coressl.jp/listening-test.coresv.net/img2/quality5.svg
Re: Opus 1.2 is out! Reply #66 – 2017-09-13 14:46:13 Quote from: eahm on 2017-09-13 05:54:03Kamedo2, I see the same graph there.Sorry, updated. Original: https://opus-codec.org/static/comparison/quality.svgMy rework: https://ss1.coressl.jp/listening-test.coresv.net/img2/quality6.svg
Re: Opus 1.2 is out! Reply #67 – 2017-09-13 21:07:03 On Debian Stretch I didCode: [Select]apt install opus-toolswget https://archive.mozilla.org/pub/opus/opus-1.2.1.tar.gzunp opus-1.2.1.tar.gzcd to there./configuremakesudo make installsudo ldconfigopusenc --versionopusenc opus-tools 0.1.10 (using libopus 1.2.1)Copyright (C) 2008-2017 Xiph.Org FoundationWould that be ok? Last Edit: 2017-09-13 21:09:41 by smok3
Re: Opus 1.2 is out! Reply #68 – 2017-09-13 21:29:26 Better to ask here I guess: how do I put Opus in a CAF container with foobar2000?
Re: Opus 1.2 is out! Reply #69 – 2017-09-13 23:57:24 Quote from: Kamedo2 on 2017-09-13 14:46:13Original: https://opus-codec.org/static/comparison/quality.svgMy rework: https://ss1.coressl.jp/listening-test.coresv.net/img2/quality6.svgIs the lower contrast intentional?Also, when it comes to fullband mono and fullband stereo, there's no smooth transition as such. There should be some clarity that there's an overlap, or even better: make two different diagrams altogether.I'd love to add some more codecs, though. Especially AMR-WB+, AC3, Atrac, G.729, and G.729.1 (recently expired patents).
Re: Opus 1.2 is out! Reply #70 – 2017-09-14 05:36:24 Quote from: eahm on 2017-09-13 21:29:26Better to ask here I guess: how do I put Opus in a CAF container with foobar2000?FFmpeg will likely add this to its CAF muxer* in the near future, if it hasn’t already. Combined with lib opus encoding, this should be able to target iOS 11 devices.*By add, I mean to its list of supported codecs.
Re: Opus 1.2 is out! Reply #71 – 2017-09-14 15:38:59 Quote from: polemon on 2017-09-13 23:57:24Is the lower contrast intentional?Yes, intentional. Many modern color designs are like that.Quote from: polemon on 2017-09-13 23:57:24Also, when it comes to fullband mono and fullband stereo, there's no smooth transition as such. There should be some clarity that there's an overlap, or even better: make two different diagrams altogether.I'd love to add some more codecs, though. Especially AMR-WB+, AC3, Atrac, G.729, and G.729.1 (recently expired patents).Please consider uploading your version of graph(s). It will be a great help to me.
Re: Opus 1.2 is out! Reply #72 – 2017-09-15 04:26:31 Code: [Select]afconvert -d opus -f caff -q 127 -b 48000 -s 3Manages to produce mono Opus streams on macOS High Sierra developer beta 9, I have yet to test on the GM seed, which I am about to install over my stable Sierra installation.I also made a 3 line patch to avformat / {caf,cafenc}.c, which enables muxing the Opus codec into CAF containers. I have verified that a stereo stream plays back properly on High Sierra, same version, and will upload to my iCloud Drive and verify whether it plays on my iOS 11 GM device.
Re: Opus 1.2 is out! Reply #73 – 2017-09-15 08:53:06 Quote from: Kamedo2 on 2017-09-13 14:46:13Quote from: eahm on 2017-09-13 05:54:03Kamedo2, I see the same graph there.Sorry, updated. Original: https://opus-codec.org/static/comparison/quality.svgMy rework: https://ss1.coressl.jp/listening-test.coresv.net/img2/quality6.svgMaybe AAC could also be extended to go below 32Kbps? The only problem is that quality and bandwidth is mixed, so it might be a straight line extending to the left.I think a better graph would be a graph that nearly looks the same, but with the 'narrowband, wideband etc.' sections removed and the color of the line determines the bandwidth.Like 'Yellow = Narrowband, Orange = Wideband, Fullband = Green etc.'
Re: Opus 1.2 is out! Reply #74 – 2017-09-18 18:21:34 Quote from: LithosZA on 2017-09-15 08:53:06Maybe AAC could also be extended to go below 32Kbps? The only problem is that quality and bandwidth is mixed, so it might be a straight line extending to the left.I think a better graph would be a graph that nearly looks the same, but with the 'narrowband, wideband etc.' sections removed and the color of the line determines the bandwidth.Like 'Yellow = Narrowband, Orange = Wideband, Fullband = Green etc.'Indeed. The quality and bandwidth is mixed, and it's a tricky problem. Adding a footnote for the Opus at 14 - 32kbps may be a better idea.Footnote: Opus at 14 - 32kbps is actually a fullband, but the quality is comparable to that of other wideband encode.
