Topic: [TOS #6] foobar replaygain stuck at 89db?? (Read 5893 times) previous topic - next topic
I am relatively new to foobar but am now using it to add replaygain to my flac's.  At the default setting of 89db I find it a bit low so wanted to set it to 92db instead.  I go to preferences/advanced/replaygain and set "target volume level" to 92 instead of the default 89.  I cleared replaygain info from a file and told it to scan per track gain.  It comes up with the exact same -11 value that it did the first time when it was set to 89db.  I tried it again and set the target volume to 98db, same thing, it still comes out with -11.
I have replaygain 2.2.2 and foobar 1.3.15.
Either I am missing something or changing the target volume simply has no effect at all.
Re: foobar replaygain stuck at 89db??
ReplayGain target level isn't adjustable as it's a standard. There are quite many threads about this that at least Google search finds instantly. A few in chronological order: 1, 2, 3, 4 and 5.
In the replaygain page of the settings, you can add preamplification, to adjust the final loudness of replaygained files. +4 or even +6 dB should be possible with modern music, with no issues.
