Topic: How do I update this field? (Read 1922 times) previous topic - next topic
In the attached image, how do you update the 'Disc' column??
I've tried using the file properties 'Details' tab but don't see it there.  Also, I tried Mp3tag but still can't figure it out.
Thanks in advance!
Re: How do I update this field?
Sorry for not being able to answer your question, perhaps someone from Microsoft or with debugging skills can determine that. But if you are after the disc number column it's called "Part of set" in Explorer.
Select the file in Mp3tag and press ALT+T.  That should pop up an editor with all extended tags.
Thanks for the replies.  After further research, I don't think this is field is supported by Windows, and so please close this thread.
