Topic: how to compress 93gb speech mp3 files with low noise using lame. (Read 3837 times) previous topic - next topic
Hi I am Rupesh from India. I have a huge directory of size 93.5 gb with 8500 mp3 files and 2000 sub directories.
All these mp3s are speeches recorded by someone at 64 kbps. I want to compress these files recursively using lame with 16 kbps bit rate and 11050 sample rate.
I have compressed the above huge directory with above options using ffmpeg and the resulted destination directory size was 29.5 gb and the quality was not good. Then I thought instead of compressing using ffmpeg it is better to compress using lame.
I have compressed some directories with options given below using lame and the quality was not good.
 lame    --abr 20 -m j -q 0 --resample 22.05 --priority 4
lame    --abr 16 -m j -q 0 --resample 11.025 --priority 4
lame    --abr 16 -m j -q 0 --resample 22.05 --priority 4
The files I converted using ffmpeg was better than the files converted using lame.
In the above sound quality was not good I mean after the compression completed when I try to play these files on any music player I am getting    sounds like sshhh... garrr... and some electronic noises.
Please try to suggest optimal settings to compress these speech mp3 files I mean less noises like sshhh garrrr and other such electronic noises.
Are there any other ways to reduce these noises during the process of compression.
I think that sample rate and bit rate play a lead role together in compression I mean it is not feasible to use 44.1 kHz to 16 kbps bit rate and so suggest the correct sample rate to 16 kbps and 24 kbps.
If it is not possible to eliminate these noises in 16 kbps bit rate try to suggest at other bit rates upto 24 kbps.
As I am new to audio compression please suggest optimal settings I mean bitrate below 24 kbps, sample rate to the corresponding bitrate, replay gain, athtype, highpass, low pass etc., found in lame documentation.
Regards,
Rupesh.
Regards,
Rupesh.
Re: how to compress 93gb speech mp3 files with low noise using lame.
I think you're confusing bit-RATE with bit-DEPTH.
mp3 has no bit-depth. When decoded and played, they'll probably all be 16-bit, according to your sound card settings, so you don't have to think about that when compressing to mp3.
16kbps is the bitrate, the amount of data per second, and it's very low. Try something higher. 64 is also low, but usually okay for speech. You're also transcoding from lossy to even more lossy, wich will enlarge any artifacts that were in the 64kbps version.
You might be able to get away with a lowpass of 8KHz or lower, but you'll have to test a few files and see if it sounds okay.
Encode to mono:
lame --abr 16 -m m --resample 11025
I know the OP asks for LAME mp3s, but maybe one should give Opus a shot?  I have no idea how artifacts compound when encoding first to 64 and then to 16.
(Of course you keep the originals, right?)
I bet you can save some gigabytes losslessly using mp3packer. Have you tried it? It's included with FileOptimizer at Sourceforge (if you want GUI). Or else there is WinMP3Packer.
Yes I have created those new threads because those are specific to the corresponding topic and those threads will attract more viewers.
ok, I'm sorry for my doubt.
My original advice still stands, that 16kbps is probably too low for good speech.
Going from 64 to 32kbps and from stereo to mono should reduce the data to 25% while still keeping acceptable quality.
Going from 64 to 32kbps and from stereo to mono should reduce the data to 50% while still keeping acceptable quality.
Stereo to mono does not (roughly) half the data?
No. A 128kbps stereo mp3 is 128kbps not 256kbps.
the bitrate is not connected to the amount of channels but is the total bitrate for the file, de bitrate is then shared between the channels via pure stereo or joint stereo mode (or dual mono IIRC).
PS. I would go for the Opus codec. It's way better than MP3 at low bitrates.
Why have I never heard about that before?
... I see that the FAQ is full of explanations why this-and-that particular operation is not lossless. Use with caution then.
Some of you suggested to use opus codec instead of mp3 at 16 kbps and so I want to use mp3 at higher frequencies and bitrates. I am going to use opus codec for speech files at 16 kbps.
Regards,
Rupesh.
When encoding in mono, the single channel gets twice as much data as one channel encoded in dual mono at the same bitrate.
When encoding in L+R, one channel can get more data than the other in a given frame.
When encoding in L+R/M+S, data can also distributed as the encoder sees fit.
Since L/R and M/S are mathematically equivalend, both L+R/M+S (joint-stereo) and L+R (stereo) are "pure stereo".
Oh derp, of course.
I was literally thinking that while typing that post, my brain must have partially switched off or something.
