Topic: How to change the filter coefficients according to the sampling rate? (Read 1195 times) previous topic - next topic
Hello everyone,
I have a set of direct form 2 filter coefficients, which is for 48kHz(given ITU R for loudness calculation).
Now I want to modify these coefficients according to 44.1 kHz sampling rate. Could anyone please help me in this?
I know there is discussion which talks about this, but i couldn't understand that.
Many Thanks
Re: How to change the filter coefficients according to the sampling rate?
Hello everyone,
Many Thanks
IIRC, it's quite difficult task to re-calculate samplerate specific coefficients suitable for other samplerates (not accurate process).
Also, why not just solve the filter types/parameters used for the curve ... ?
Any link to the discussion and paper/source you got those coefficients from?
As an addendum for previous post;
If you have EqualizerAPO installed then it's quite easy to find the filter parameters by using Configuration Editor. Enter your filter coefficients for Filter: commands and then use those pre-defined filters as inverted (change the Hz, Q and Gain values to make the graphics show flat response).
https://s3.postimg.org/jpwzma5cx/BS1770.png
After getting the right filter parameters, just find some filter calculation web page to do the job for you or calculate coefficients by yourself using MatLab/Octave :
% Octave packages --------------------------------------
pkg load control
pkg load signal
% Uses RBJ Cookbook formulas
% http://www.musicdsp.org/files/Audio-EQ-Cookbook.txt
fs = 44100;
% HPF coefficients
f = 38;
Q  = 0.5;
w0 = 2*pi*f/fs;
cw0 = cos(w0);
sw0 = sin(w0);
alpha = sw0/(2*Q);
hp_b0 = (1+cw0)/2
hp_b1 = -(1+cw0)
hp_b2 = (1+cw0)/2
hp_a0 = 1+alpha
hp_a1 = -2*cw0
hp_a2 = 1-alpha
% HSF coefficients
db = 4.0;
f = 1500;
Q  = 0.707;
w0 = 2*pi*f/fs;
cw0 = cos(w0);
sw0 = sin(w0);
alpha = sw0/(2*Q);
a = 10^(db/40);
tmp = 2*sqrt(a)*alpha;
hs_b0 =   a*((a+1)+(a-1)*cw0+tmp)
hs_b1 =  -2*a*((a-1)+(a+1)*cw0)
hs_b2 =   a*((a+1)+(a-1)*cw0-tmp)
hs_a0 =   (a+1)-(a-1)*cw0+tmp
hs_a1 =   2*((a-1)-(a+1)*cw0)
hs_a2 =   (a+1)-(a-1)*cw0-tmp
Is this the discussion you didn't understand?
https://hydrogenaud.io/index.php/topic,76394.0.html
If so, better to ask questions about what you didn't understand.
I posted this update to that old thread:
By MathWorks: ( https://www.mathworks.com/help/audio/ref/weightingfilter-class.html?s_tid=gn_loc_drop )
"These coefficients are recomputed for nonstandard sample rates using the algorithm
described in Mansbridge, Stuart, Saoirse Finn, and Joshua D. Reiss. "Implementation
and Evaluation of Autonomous Multi-track Fader Control
." Paper presented at the
132nd Audio Engineering Society Convention, Budapest, Hungary, 2012.
(AES Convention Paper 8588)
