Re: 2017 Format Poll (lossy codecs)
Reply #51 –
@eahm ; I got that 'makeportable' batch file to work this time simply because i noticed it created a folder called 'QTfiles' inside of the working TEMP folder i made (like i put batch file and iTunesSetup.exe into that TEMP folder) and then i loaded up the command prompt in administrator mode (i don't know if that part is needed or not but i did that to ensure it functioned properly) and then went to the D:\TEMP\ folder and then ran the 'makeportable' (without the ') and hit enter and i seen it do something real quick in the dos window but at that point i figured it was all automatic and tried to encode a Apple AAC file like usual in Foobar2000 but it failed and then i went and checked the D:\TEMP\ folder and noticed it made a 'QTfiles' folder at which point i took a guess and copied and pasted the entire 'QTfiles' folder to Foobar2000's 'encoders' folder and then tried encoding a Apple AAC file like usual and it worked!
but i wonder if i can simply just put those two files into a folder and then right click the 'makeportable.bat' file and select 'run as administrator' will do the trick (or can i just click the makeportable without the admin mode?) or do i have to manually run things from a command prompt like i did. i guess i could test but ill see what you think first.
but that does cut down on file size a bit as it's "37.7 MB (39,543,904 bytes)" (although if i compress the 'QTfiles' folder with 7-zip that shrinks it down to only "9.23 MB (9,684,216 bytes)"
) vs the .msi file (i.e. 43.8 MB (45,940,736 bytes)) and i don't need to have any from Apple installed as this seems more of a proper way to use these things. but it does not come with any basic instructions as i could easily see how some people would not know what to do even if they got the basic 'iTunesSetup.exe' and 'makeportable.bat' into the same folder and then executed the .bat file as i imagine running it straight up without actually going to a command prompt will probably flash the window quickly and one will wonder what the hell happened.
but once you confirm what i was asking above ill edit my couple of posts suggesting people use the AppleApplicationSupport.msi and guide then to that makeportable.bat instead. but even though you and i prefer the way you just recommended to me i could see why the average person would rather do things the way i initially described with the .msi file because it's a bit quicker/simpler to get things up and running as a bit less computer knowledge is needed. because i am just hoping to tell someone to create a TEMP folder and put those two files (i.e. iTunesSetup.exe (the 32bit one) and makeportable.bat) into the TEMP folder and then simply execute the .bat file and then tell them to copy the created 'QTfiles' folder to Foobar2000's installation folder under the 'encoders' folder and then they are golden
p.s. the two Winamp FhG files compressed with 7-zip are only 420 KB (430,781 bytes) in size. but it seems this encoder is only worth using if someone wants files around 32-48kbps etc and being more of the AAC-HE standard which is more CPU intensive etc.
I am able to hear distortion in the bass with my iPhone in speaker mode at 64 for Opus but I can't distinguish at 96, didn't try 80 but I'll do more testing that's why I didn't "report" anything yet.
Okay, thanks for the info.
it's cool, as i know what i said some people will have differing opinions and all as like i said i was just doing a pretty quick test and found @ 64kbps things were not obviously off at that point without spending much time listening to sounds more focused etc. so it's possible i could notice some artifacts if i put more effort into it but i think 64kbps is up to a standard that the overall sound is not obviously weak(especially given it's not far from 96kbps which people seem to think positively of), even though i would have no doubts that some users here would have no problem picking up on it. but if i recall correctly i think i read that someone who's trained to spot artifacts can pick up on them more easily than people like me who likely can't etc(?). because i guess when i listen to music in general i am mainly focused more around the singers voice than anything else as long as there is no obvious weird fluctuations in the overall sound outside of that it will probably be harder for me to notice(i know some people can give some pretty technical terms to specifically point out what it is they are hearing but i don't know all of that technical terms on what i am hearing other than something is off or not etc).
but are those iPhone speakers any good? ; it seems like those would be harder to notice unless those speakers on there are better than i think they are as i never played around with a iPhone, pretty much. so ill just have to take your word for i.
