Topic: Batch file to split FLAC image files into tracks (Read 3078 times) previous topic - next topic
This question comes up often enough, so in the hopes that it might be useful to someone else, here's a batch file I wrote to split a FLAC image file into individual tracks.  It's rudimentary, but it does what I need it to.  Note that it requires the freeware utilities Tag.exe and SHNTool.exe, and that you'll need to change the %EXEPATH% variable to point to whatever location you install them in.
@echo off
setlocal EnableDelayedExpansion
REM *** define variables
set EXEPATH=C:\Portable Apps
set TAG="%EXEPATH%\Tag.exe"
set SHNTOOL="%EXEPATH%\SHNTool.exe"
set "FILE_SCHEME="^%%n ^^ ^%%t""
set "TAG_SCHEME=[A] L\N ^ T"
REM *** make a folder to hold the output
for /f "tokens=*" %%g in ('dir /b *.flac') do          (
  set "NAME=%%~ng"
  set "FOLDER=%%~ng"
  if not exist "!FOLDER!" md "!FOLDER!"
  REM *** extract the embedded CUE sheet
  %TAG% --tocuea "!FILE!.flac"
  ren "!FILE!.flac.cue" "!FILE!.cue"
  REM *** split the image file into individual tracks
  %SHNTOOL% split -f "!FILE!.cue" "!FILE!.flac" -d "!FOLDER!" -t !FILE_SCHEME! -o flac
  REM *** and make tags from the file names
  %TAG% --auto --scheme "!TAG_SCHEME!" "!FOLDER!\*.flac"
endlocal
echo Finished.  Press any key to exit.
pause > nul
exit
Re: Batch file to split FLAC image files into tracks
Here's an updated version that does a better job handling tags (the first version reassembled the tags from the file names, which meant all "reserved" characters like question marks, colons and forward-slashes were lost) and prevents tiny "pregap" files from being created.
REM *****  initialize  *****
cls
@echo off
REM *****  split FLACs  *****
  set "FILE=%%~ng"
  set "FOLDER=%%~ng"
  if exist "!FILE!.cue" copy "!FILE!.cue" "!FILE! (old).cue" & del "!FILE!.cue"
  tag --hidetags --hideinfo --hidenames --simple --tocuea "!FILE!.flac"
  if exist "!FILE!.flac.cue" ren "!FILE!.flac.cue" "!FILE!.cue"
  REM *****  parse CUE sheet  *****
  for /f "usebackqdelims=" %%a in ("!FILE!.cue") do (
      set "LINE=%%a"
      echo !LINE! | findstr /i /c:"INDEX" > nul & if errorlevel 1 (
        set "LINE=!LINE:?=!"
        set "LINE=!LINE:/= - !"
        set "LINE=!LINE::= -- !"
        set "LINE=!LINE:  -= -!"
        set "LINE=!LINE:-  =- !"
      echo !LINE!
  )>"!FILE!.tmp.cue"
  if exist "!FILE!.tmp.cue" (
    ren "!FILE!.cue" "!FILE! (embedded).cue"
    ren "!FILE!.tmp.cue" "!FILE!.cue"
  SHNTool split -f "!FILE!.cue" "!FILE!.flac" -d "!FOLDER!" -t !FILE_SCHEME! -o flac
  if exist "!FOLDER!\* pregap.flac" del "!FOLDER!\* pregap.flac"
REM *****  tag FLACs  *****
  if not exist "!FILE! (embedded).cue" (
    tag --auto --scheme "!TAG_SCHEME!" "!FOLDER!\*.flac"
    goto JUMP
  set "CUE_SHEET=!FILE! (embedded).cue"
  set COUNT=0
  for /f "tokens=*" %%a in ('findstr /i /v /r /c:"^ *INDEX " /c:"^ *FILE " /c:"^ *REM " "!CUE_SHEET!"') do (
    set "INPUT=%%a"
    set INPUT=!INPUT:"=!
    echo !INPUT! | findstr /C:"TRACK" > nul & if not errorlevel 1 (
      call :TAG
      set "ARTIST="
      set "TRACK=!INPUT:TRACK =!"
      set "TRACK=!TRACK: AUDIO=!"
    echo !INPUT! | findstr /C:"TITLE" > nul & if not errorlevel 1 (
      if defined TRACK (set "TITLE=!INPUT:TITLE =!") else (set "ALBUM=!INPUT:TITLE =!" )
    echo !INPUT! | findstr /C:"PERFORMER" > nul & if not errorlevel 1 (
      set "ARTIST=!INPUT:PERFORMER =!"
      if not defined TRACK set ALBUM_ARTIST=!ARTIST!
  call :TAG
  set TRACK_ID=0
  for /f "tokens=*" %%i in ('dir /b "!FOLDER!\*.flac"') do (
    set /a TRACK_ID=TRACK_ID + 1
    set "TRACK_NAME=%%i"
    call set TAG=%%VAR[!TRACK_ID!]%%
    tag "!FOLDER!\!TRACK_NAME!" !TAG!
  :JUMP
   echo > nul
REM *****  clean up and exit  *****
  del "!FILE! (embedded).cue"
  md "!FOLDER! (album)"
  move "!FILE!.cue" "!FOLDER! (album)"
  move "!FILE!.flac" "!FOLDER! (album)"
  move "!FOLDER!" "!FOLDER! (tracks)"
endlocal
cls
echo. & echo. & echo. & echo. & echo. & echo.
pause > nul
exit
REM *****  SUBROUTINES  *****
:TAG
 if defined TRACK (
    if defined TITLE (
      if not defined ARTIST set "ARTIST=!ALBUM_ARTIST!"
      set /a COUNT=!COUNT!+1
      set VAR[!COUNT!]=--track !TRACK! --artist "!ARTIST!" --album "!ALBUM!" --title "!TITLE!"
      call echo %%VAR[!COUNT!]%%
  goto :eof
nothing works here...but interesting idea
An alternative tool could be the CUETools command-line: http://cue.tools/wiki/CUETools#Command_line_options
“It sounded bad to me. Digital. They have digital. What is digital? And it’s very complicated, you have to be Albert Einstein to figure it out.”
- Donald Trump, May 2017
