Topic: Equalizing headphones, with binaural microphones? (Read 556 times) previous topic - next topic
About 3 weeks ago I started experimenting with binaural microphones that are placed at the ear canal. Of course, these are meant to create binaural recordings to play back on headphones, however I found a second use for them. I posted what I did here: http://www.head-fi.org/t/829549/equalizing-headphones-to-your-ears-with-in-ear-binaural-microphones
Essentially, I took measurements of my headphones in order to get their frequency response using Room EQ Wizard. Then, I equalized their response to match a typical speaker target curve.
So, my question, is my little experiment here an effective way of EQing properly? The frequency response the microphones are picking up are right at the entrance of the ear canal, and I know many measurement dummy heads have microphones inside of the ear canal where the eardrum would be. What I'm hearing sounds pretty good with the headphones I have, but I would like feedback anyway.
Re: Equalizing headphones, with binaural microphones?
That's reasonable if the microphones are accurate and calibrated.    But, headphone measurements are a bit tricky and if the headphones are reasonably good I'd start with the assumption are about as good as the microphones.
I wouldn't EQ headphones unless you're not happy with the sound.   If you feel there's "something wrong", or if you just have a preference for more bass or more highs, etc., adjust by ear.
If you're not shooting for flatness/accuracy, why not just adjust to your taste?
If you're happy with the results that's the important thing.     I wouldn't worry too much about "accuracy" unless you are mixing/mastering binaural recordings.   And in that case, it's probably safer to just get a good pair of headphones for your "standard".    (And if you're mixing/mastering regular recordings, headphones shouldn't be your primary monitors anyway.)
