Re: Seedeclip4 Mediaplayer entry deleted, edits undone and user blocked. Why?
Reply #52 –
The dishonesty of your analyser.
The dishonesty of my free analyser, that you've now used several times for free?
Do you have a dishonest power drill at home?
If someone post the screenshots like I do in some forums and criticizing the quality of modern pop, or which specific pressing or release of the same album is the best (based on the analysis result) and so on, can your analyser actually tell which version sounds more dynamic and less clipped to someone?
The clip analysis, dynamic range and histogram give in my view a very complete picture of the mastering quality. It's possible the rating may be improved one day - very few things are as good as they'll ever be - Windows 3.0 and DOS 6.0 taught us that.
I asked for someone to find an unclipped modern pop track and you showed me a track with several thousand clips - some of them quite visible and severe. What am I missing in this picture?
I listened to the files I posted, apart from the inevitable noise and frequency response change in the cassette version, other versions sound identical to my ears, I mean I cannot ABX them after level matching. You asked me to see flat-tops, yes I can clearly see them but how about listen to them? Actually the cassette version sounds worse than other versions in my opinion due the limitation of cassette technology, obviously not "Ace" quality. It doesn't sound more dynamic, unclipped or pleasing to me.
You are confusing mastering quality with sound quality.
I can have a perfectly mastered recording of a cheap transistor radio, it doesn't mean it's good sound does it?
If you are happy to listen to sound that you can plainly see to be distorted then you clearly don't need to pay for any declipping capability or even buy better mastered music. So we've just saved you some money which can only be a good thing right?
I can predict if I capture the waveform of the full version of SeeDeclip and analyze it the quality score will also greatly improved due to the flawed algorithm of your analyzer. So it also lies about the effectiveness or your declipper, as well as a cassette deck, a phase shifter or declippers from other competitors. Is it honest?
The analyser didn't look flawed to me. It detected the flat-tops you had perfectly and even showed you where they were.
It didn't bother looking at the lower level waveform, I suggest you update the program if you want to stay up to date.
