Re: FLAC v1.3.2 Final Reply #75 – 2018-06-14 18:38:04 Thanks for the build again, why is sox.exe included too now?
Re: FLAC v1.3.2 Final Reply #76 – 2018-06-14 19:58:30 Quote from: eahm on 2018-06-14 18:38:04Thanks for the build again, why is sox.exe included too now?A little mistake when adding the files to the archive....... Last Edit: 2018-06-14 20:00:59 by NetRanger
Re: FLAC v1.3.2 Final Reply #77 – 2018-08-20 15:59:35 FLAC v1.3.2 (Git 2018-08-20)Built on August 13, 2018, GCC 7.3.0(32bit)/8.2.0(64bit)Latest commit included : cdb030chttps://xiph.org/flac/https://git.xiph.org/?p=flac.git;a=summary
Re: FLAC v1.3.2 Final Reply #78 – 2018-08-20 16:14:47 Hmm, I'm kinda wondering, if FLAC will ever be expanded beyond 8 channels. I was looking into shoe-horning more channels into FLAC, breaking the spec, but I've only seen projects that gave up.
Re: FLAC v1.3.2 Final Reply #79 – 2018-08-20 16:17:40 Quote from: polemon on 2018-08-20 16:14:47Hmm, I'm kinda wondering, if FLAC will ever be expanded beyond 8 channels. I was looking into shoe-horning more channels into FLAC, breaking the spec, but I've only seen projects that gave up.FLAC in Matroska?
Re: FLAC v1.3.2 Final Reply #80 – 2018-08-20 16:19:33 Quote from: Porcus on 2018-08-20 16:17:40FLAC in Matroska?Good call. I'll check it out if it works for me. Would be nice if more hardware supported Matrsoska, though.
Re: FLAC v1.3.2 Final Reply #81 – 2018-08-27 10:30:38 FLAC v1.3.2 (Git 2018-08-25)Built on August 27, 2018, GCC 7.3.0(32bit)/8.2.0(64bit)Latest commit included : 0897458https://xiph.org/flac/https://git.xiph.org/?p=flac.git;a=summary
Re: FLAC v1.3.2 Final Reply #82 – 2018-08-27 17:13:06 Quote from: polemon on 2018-08-20 16:19:33Quote from: Porcus on 2018-08-20 16:17:40FLAC in Matroska?Good call. I'll check it out if it works for me. Would be nice if more hardware supported Matrsoska, though.Would be quite a scenario if your hardware does support FLAC and does support > 8 channels, but not Matroska ... ffmpeg has experimental support for FLAC-in-mp4, but I don't know if anything would play it.If WavPack is an option, then I see a list of 18 channels at http://www.wavpack.com/wavpack_doc.html Should maybe the Lossless comparison wiki article be updated with channel limitations? https://wiki.hydrogenaud.io/index.php?title=Lossless_comparison
Re: FLAC v1.3.2 Final Reply #83 – 2018-08-28 14:06:28 Quote from: Porcus on 2018-08-27 17:13:06Would be quite a scenario if your hardware does support FLAC and does support > 8 channels, but not Matroska ... ffmpeg has experimental support for FLAC-in-mp4, but I don't know if anything would play it.If WavPack is an option, then I see a list of 18 channels at http://www.wavpack.com/wavpack_doc.html Management decision, so to say. I use FLAC to save the panadapter section of my ham radio receiver. Using FLAC makes it relatively easy, because I can handle it like any other sound file in things like Audacity, and I can still use the 655MHz bandpass FLAC allows to encode the entirety of my 10MHz window maximum of baseband. Why the >8 Channels I hear you ask? Because I'm using up to 20 of these windows side-by-side (20 receivers). Putting them all into one file (as they're recorded simultaneously), is just more convenient.
Re: FLAC v1.3.2 Final Reply #84 – 2018-08-28 17:30:51 Quote from: polemon on 2018-08-28 14:06:28Management decision, so to say. I use FLAC to save the panadapter section of my ham radio receiver. Using FLAC makes it relatively easy, because I can handle it like any other sound file in things like Audacity, and I can still use the 655MHz bandpass FLAC allows to encode the entirety of my 10MHz window maximum of baseband. Why the >8 Channels I hear you ask? Because I'm using up to 20 of these windows side-by-side (20 receivers). Putting them all into one file (as they're recorded simultaneously), is just more convenient.Huh, now you made me read specs ... So FLAC has max 8 channels (so obviously not intended for multitrack recording, hm? To the level where they could not afford even a full byte?). Good news is that you can set the number of samples to zero for "unknown", since then you are not bound by the less-than-an-hour 2^36 samples for 20 MHz sampling rate. WavPack on the other hand provides for custom sampling rates and 256 channels - but is not supported by Audacity. According to https://wiki.audacityteam.org/wiki/FFmpeg_integration#table , Audacity can read WavPack by way of ffmpeg - but not write. IDK whether that is an ffmpeg limitation, but the ffmpeg doc says it only supports WavPack encoding at 32-bits integer, and that was maybe not what you wanted. But same source claims Audacity can read & write .mka by way of ffmpeg, so why not try your luck at FLAC ...
Re: FLAC v1.3.2 Final Reply #85 – 2018-08-28 17:58:10 @Porcus Yeah, I thought I'd use MPEG-4 ALS, too, but it seems that there's very little software support. MPEG-4 SLS is a similar problem, also it seems the specs aren't fully determined.I was looking into WavPack, too. 1Hz - 16.777MHz sampling rate, 256 channels.The more obscure formates, like True Audio are a lot better: 0 (DC) - 4GHz sampling rate, up to 65535 channels (same specs as MPEG-4 ALS). Unfortunatelly, those formats are also not the best when it comes to software support. I mainly handle them in command line, too, as in this case latency isn't really much of an issue, etc. For Recording I use either FFmpeg or SoX.
Re: FLAC v1.3.2 Final Reply #86 – 2018-08-29 03:39:16 One other thing I forgot to mention in my previous post:I prefer command line programs doing one thing but doing that rather convenient. I know FFmpeg is fully featured and everything, combines everything into one thing, nice, etc. but tbh. I prefer having a flac, opusenc, or an mkvmerge.SoX is almost always my go-to solution, when something has to be rigged up there and then. I found myself numerous times having to fix something up, so it "just records" or "just converts" something. Having something "just stream" a video, I did that a couple times with FFmpeg. Some things I can only do with FFmpeg, short of using libavf and libavcodec in my own program.
Re: FLAC v1.3.2 Final Reply #87 – 2018-09-17 09:36:48 FLAC v1.3.2 (Git 2018-09-02)Built on September 16, 2018, GCC 7.3.0(32bit)/8.2.0(64bit)Latest commit included : faafa4chttps://xiph.org/flac/https://git.xiph.org/?p=flac.git;a=summary
Re: FLAC v1.3.2 Final Reply #88 – 2018-09-21 14:28:46 FLAC v1.3.2 (Git 2018-09-19)Built on September 21, 2018, GCC 7.3.0(32bit)/8.2.0(64bit)Latest commit included : 421961fhttps://xiph.org/flac/https://git.xiph.org/?p=flac.git;a=summary
Re: FLAC v1.3.2 Final Reply #89 – 2019-02-04 18:35:52 FLAC v1.3.2 (Git-2019-02-01)Built on February 04, 2019, GCC 7.4.0(32bit)/8.2.1(64bit)Latest commit included : cc15b74https://xiph.org/flac/https://git.xiph.org/?p=flac.git;a=summary
