Topic: My components (Read 23248 times) previous topic - next topic
Re: My components
Reply #75
I can ask Peter about that, but basically, prior to some semi-recent changes to my component, it would "cheat" to ensure it gained total priority over all AAC formats if installed. Some users asked this to be reduced to its current state, because they care about their > ±1.0 peaks on AAC files being properly represented by a floating point decoder, which this component is not.
Re: My components
Reply #76
So. it's not possible to decode only HE-AAC 960 by this component but leave other LC and HE flavors to the built-in decoder?
Re: My components
Reply #77
It may be possible, if the internal component actively rejects such streams and hands them off to me. And if I actively accept HE-AAC only if it's 960.
I still have to ask Peter about it, because his component doesn't reject such files, so I'd only get them if my component happened to accept HE-AAC and by chance was a higher priority due to the load order.
Re: My components
Reply #78
It is done.
Re: My components
Reply #79
Thanks. Will it work as expected with next fb2k update?
Re: My components
Reply #80
What exactly do you mean? It works here. I guess it requires an update to the player for the player to not decode these formats itself.
Re: My components
Reply #81
Indeed, it works with 1.6.1 beta.
Re: My components
Reply #82
I'll be introducing a new feature for 1.6.1 beta and newer as well. Basically, an input component attribute hook that only just got implemented into regular use by 1.6.1 and up, it will allow any input which supports variable sample rates on its own, to automatically configure itself during normal playback to match the settings of the output stream, so that outputs don't need to resample anything you give them.
So, for instance, all of my synthesizer and emulator components which support variable output rate, can do their own resampling or mixing at a different rate, instead of requiring the user to configure a rate, which may or may not be resampled anyway.
