Topic: My components (Read 21523 times) previous topic - next topic
Re: My components
I mean loading cursor, sorry :)
I didn't have any other vsti plug-in to test, and now I know a bit more about how it works with foobar2000. thank you and I hope you will reach your goal next month :)
Re: My components
hi kode54, is foo_midi supposed to work with SC-VA 1.0.7? I tried it but doesn't work. Regards. Thanks. :)
Re: My components
It's only been tested with version 1.0.3 of SCVA.
¡Se habla español! Also available in purple and orange.
Re: My components
It has now been tested with 1.0.7, and verified to work.
Re: My components
Thank you so much. Yes, I used to use it with v1.0.3 but just tried it yesterday with v.1.0.7. Nice to have it update, though I haven't known yet what's update from dll itself, hehehe. Regards. :)
Re: My components
Hi, kode54, wanna ask you about OpenMPT component
Any difference between OpenMPT components from you and from OpenMPT website? Component that you posted didn't include openmpt-mpg123.dll like I found in v.0.3.x.
Will there an option page like the one that present on OpenMPT for XMPlay?
Thanks. Regards :)
Re: My components
It uses statically linked minimp3 and stb_vorbis instead of externally linking the larger mpg123 and libvorbis. There are preferences in the Decoders section of the Advanced Preferences page, like the official component.
Re: My components
Reply #32
@kode54 , foo_ac3 0.9.9 doesn't work without SSE2. Since it is your only component that requires SSE2, i want to ask: wasn't this requirement added by mistake? Or is it because of the bug in MSVS?
Re: My components
Sorry, it'll require SSE2 even if I disable optimization. I checked. Well, I sort of checked. I don't know if most of the SSE2 crap I found in a disassembly is just optional code paths of the C runtime.
E: Scratch that, it was a false alarm disassembling part of a data table, and the rest should be run time switched SSE2 code that only executes if support is detected.
Re: My components
Reply #34
Problem is fixed in 0.9.10. It works without SSE2.
Re: My components
Reply #35
hi, kode54,
PSF decoder component page still has warning "NOTE: Please only install _ONE_ PSF Decoder at a time!"
foo_dumb 2.0.3, does it still use DUMBv2.0.2? about dialog box says this
by the way, any respond to this?
regards  :)
Re: My components
Reply #36
Response is already on my blog. About dialog will be fixed when I get around to it. Multiple PSF decoders is not really recommended anyway, since you still only get one doing anything, and the other just waiting for you to enable it.
Re: My components
Reply #37
hi kode54. I have some question
Have you consider to implement a way to display synthesizer that being use on MIDI playback?
Any solution for Secret Sauce for not creating any temp file?
And how about changing synthesizer on the fly, keep the playback?
Apply button for MUNT data path stay disabled after changing it. Could it be fixed?
Re: My components
Reply #38
hi, kode54.
After installing 7-ZIP Reader (also EX version. made by other dev), unlike other archive reader, 7-ZIP format is shown in "Set Programs Associations". Is it by design maybe?
Re: My components
Reply #39
My archive readers register associations for all supported formats.
And I already answered this in email, I think. Secret Sauce creates temporary files the same as the plugin it lifts its library from, to facilitate multiple instances in the same process. Without it, you only get one instance globally, 16 channels. And I thought I fixed that MUNT issue already.
Re: My components
Reply #40
I just checked, your foo_unpack_jma, foo_unpack_lha, and foo_unpack_unix, they don't register associations.
Thanks for all the answer. Yeah, I also sometimes check your git repo, it has been fixed. Thank you :)
Re: My components
Reply #41
Since v2.1, MIDI Player shows empty on plug-in when reopen the preference, VSTi is set before. Tested with Yamaha S-YXG50.
Re: My components
Reply #42
I just fixed that with a new release: 2.1.3.
Re: My components
Reply #43
I do fast switch between preferences page and then glitches happen after MIDI Player page. Could you check for this, kode54? Sorry, just happened to notice this just now. Thanks :)
Re: My components
Reply #44
Congratulations, you've noticed that the preferences dialog takes a while to initialize when it's configured to detect VST components. I don't see what's happening there, other than aborted initialization if you skip through the dialogs quickly.
Re: My components
Reply #45
Preferences dialog for other components are overwritten by foo_openmpt54 dialog.
Re: My components
Reply #46
This appears to be a bug in the player itself, not any of my components?
Re: My components
Reply #47
if it's not from your component, in this case, foo_midi then its probably from the player. Only you or Peter could answer that, I guess :)
Re: My components
Reply #48
hi kode54, woukd you separate preference page between your AOPSF and PSF/Highly Experimental Decoder? Installing both will only show one preference page. Thanks
Re: My components
Reply #49
You're not supposed to install both at the same time.
