Topic: Israeli security researchers use method to spy on you using earbuds (Read 2277 times) previous topic - next topic
Source
CAUTIOUS COMPUTER USERS put a piece of tape over their webcam. Truly paranoid ones worry about their devices’ microphones—some even crack open their computers and phones to disable or remove those audio components so they can’t be hijacked by hackers. Now one group of Israeli researchers has taken that game of spy-versus-spy paranoia a step further, with malware that converts your headphones into makeshift microphones that can slyly record your conversations.
Researchers at Israel’s Ben Gurion University have created a piece of proof-of-concept code they call “Speake(a)r,” designed to demonstrate how determined hackers could find a way to surreptitiously hijack a computer to record audio even when the device’s microphones have been entirely removed or disabled. The experimental malware instead repurposes the speakers in earbuds or headphones to use them as microphones, converting the vibrations in air into electromagnetic signals to clearly capture audio from across a room.
“People don’t think about this privacy vulnerability,” says Mordechai Guri, the research lead of Ben Gurion’s Cyber Security Research Labs. “Even if you remove your computer’s microphone, if you use headphones you can be recorded.”
Video
It’s no surprise that earbuds can function as microphones in a pinch, as dozens of how-to YouTube videos demonstrate. Just as the speakers in headphones turn electromagnetic signals into sound waves through a membrane’s vibrations, those membranes can also work in reverse, picking up sound vibrations and converting them back to electromagnetic signals. (Plug a pair of mic-less headphones into an audio input jack on your computer to try it.)
But the Ben Gurion researchers took that hack a step further. Their malware uses a little-known feature of RealTek audio codec chips to silently “retask” the computer’s output channel as an input channel, allowing the malware to record audio even when the headphones remain connected into an output-only jack and don’t even have a microphone channel on their plug. The researchers say the RealTek chips are so common that the attack works on practically any desktop computer, whether it runs Windows or MacOS, and most laptops, too. RealTek didn’t immediately respond to WIRED’s request for comment on the Ben Gurion researchers’ work. “This is the real vulnerability,” says Guri. “It’s what makes almost every computer today vulnerable to this type of attack.”
To be fair, the eavesdropping attack should only matter to those who have already gone a few steps down the rabbit-hole of obsessive counter-intelligence measures. But in the modern age of cybersecurity, fears of having your computer’s mic surreptitiously activated by stealthy malware are increasingly mainstream: Guri points to the photo that revealed earlier this year that Mark Zuckerberg had put tape over his laptop’s microphone. In a video for Vice News, Edward Snowden demonstrated how to remove the internal mic from a smartphone. Even the NSA’s information assurance division suggests “hardening” PCs by disabling their microphones, and repair-oriented site iFixit’s Kyle Wiens showed MacWorld in July how to physically disable a Macbook mic. None of those techniques—short of disabling all audio input and output from a computer—would defeat this new malware. (Guri says his team has so far focused on using the vulnerability in RealTek chips to attack PCs, though. They have to determine which other audio codec chips and smartphones might be vulnerable to the attack, They have to determine which other audio codec chips and smartphones might be vulnerable to the attack, but believe other chips and devices are likely also susceptible.)
In their tests, the researchers tried the audio hack with a pair of Sennheiser headphones. They found that they could record from as far as 20 feet away—and even compress the resulting recording and send it over the internet, as a hacker would—and still distinguish the words spoken by a male voice. “It’s very effective,” says Guri. “Your headphones do make a good, quality microphone.
There’s no simple software patch for the eavesdropping attack, Guri says. The property of RealTek’s audio codec chips that allows a program to switch an output channel to an input isn’t an accidental bug so much as a dangerous feature, Guri says, and one that can’t be easily fixed without redesigning and replacing the chip in future computers.
Until then, paranoiacs take note: If determined hackers are out to bug your conversations, all your careful microphone removal surgery isn’t quite enough—you’ll also need to unplug that pair of cheap earbuds hanging around your neck.
Add this to the list of reasons of why I wish Universal I/O ports should go away for good.
Universal I/O ports just seems like a cheap and lazy way of doing things that can seriously limit what you can do with your sound card.  Having used a few computers with such ports I can strongly attest to the limitations those devices tend to have.
Example: having to switch the line in for rear out or mic for a center/LFE.  It also adds to the complexity of using the device.
It was and always will be in my honest opinion a very bad idea.  Nothing convenient about it at all to me.
Re: Israeli security researchers use method to spy on you using earbuds
Pure, unadulterated paranoia. There's nothing to say of the fact that if you're currently utilizing the output to play an audio signal, it would be super obvious when it suddenly switches over to being a microphone input and stops producing any sound. Does anyone even say anything within earshot of their computer that they would be afraid of saying in public? (Hello, NSA!)
When I'm super frustrated with a game...  I tend to scream some things I don't really mean at my computer just before I walk away that would have the developers fearful for their lives...   :-[
I once committed to text form some egregious suggestions of shotgun torture for the developers of the driving school minigames from GTA:SA. It was all fun and games until one was expected to do a fucking barrel roll in a land vehicle without damaging it. As I said then, "Gee, that looks cool. Not, Gee, I wish I could be forced to perfect that technique myself to earn a pointless achievement."
An fyi for paranoid mac users; there is a free piece of software called oversight that alerts you whenever your computers camera or mic turn on.
