Topic: Encode stream with tiny_encode (Read 4113 times) previous topic - next topic
Can I encode stream with 10ms frame and the compress rate will be what when use lossy mode?
I have try to encode pcm file but, the output file size is same to original, and I did not try to decode it , do this is right??
