Re: Biography Discussion
Reply #48 –
It's worth pointing out that it's beta software & as is standard you use at your own risk, taking on responsibility. In your case I believe the reason for a particular problem with Program Files is the non-standard way you installed foobar2000 into that location that exposed an unforeseen bug.
Notice contained within the plug-in:
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
Nonetheless I have tried to be helpful by posting a solution several posts ago. You want a 100% guarantee with computers & all sorts of different scenarios - I'm afraid I can't give that. If you don't like my way, then somebody else posted a different method. As Jailhouse said, you can always do your own research as well.
But I retested with both these folders present.
"Z:\Program Files "
"Z:\Program Files"
Open command prompt. Click the top left box. Choose edit. Correct the path in the example below as required and paste it in. Press enter. Confirm the action when prompted.
rd /s "\\?\Z:\Program Files "
I tried it a few times. It worked for me. You may have to refresh windows explorer to see the correct results.
