Re: Biography Reply #75 – 2019-11-08 18:01:02 New Version: Biography 1.1.2REQUIREMENT: Spider Monkey Panel 1.2.1+Optional: FontAwesome Highly recommended for better rendering of certain buttons. If not installed, affected buttons fallback to a different style.Please post discussion here.
Re: Biography Reply #76 – 2019-12-11 18:01:35 New Version: Biography 1.1.3REQUIREMENT: Spider Monkey Panel 1.2.2+Optional: FontAwesome: Highly recommended for better rendering of certain buttons. If not installed, affected buttons fallback to a different style.Please post discussion here.
Re: Biography Reply #77 – 2020-03-14 21:14:25 Hallo there, I'm using (latest) foobar v.1.5.2. I have also SpiderMonkeyPanel, Biography and JScript Panel on latest version. It was working properly, as it should since yesterday at the afternoon: I can't see either artist pictures nor pictures from covers. I see only text (biography) but no pictures. Any suggestions please?
Re: Biography Reply #78 – 2020-05-09 17:56:09 Hey,I cannot install the component.I have this message:JScript Panel v2.3.6.1 (id:986144)Erreur de compilation Microsoft JScript:Erreur de syntaxeFile: <main>Line: 3, Col: 1Line 3: const requiredVersionStr = '1.2.2'; function is_compatible(requiredVersionStr) {const requiredVersion = requiredVersionStr.split('.'), currentVersion = utils.Version.split('.'); if (currentVersion.length > 3) currentVersion.length = 3; for (let i = 0; i < currentVersion.length; ++i) if (currentVersion != requiredVersion) return currentVersion > requiredVersion; return true;} if (!is_compatible(requiredVersionStr)) fb.ShowPopupMessage(`Biography requires v${requiredVersionStr}. Current component version is v${utils.Version}.`);
Re: Biography 1.1.3: Size artist picture Reply #79 – 2020-12-28 14:29:27 Hello all,Can anyone tell me what values I need to change to make the artist image smaller and thus give the text more space? Thank you very much.
Re: Biography 1.1.3: Size artist picture Reply #80 – 2020-12-28 14:58:38 Quote from: rolf1955 on 2020-12-28 14:29:27Hello all,Can anyone tell me what values I need to change to make the artist image smaller and thus give the text more space? Thank you very much.I've got it!! This is sooo cool done. Totally freaky. Respect and congratulations to WilB! Solution:Right click --> Layout --> Create and mange Styles --> Create New Style
