Re: Biography Reply #25 – 2017-06-01 17:37:58 New Version: JScript Biography 0.8.2Requirements are unchanged.Please post discussion here. Last Edit: 2017-06-01 17:43:36 by WilB
Re: Biography Reply #27 – 2017-07-26 18:52:03 New Version: JScript Biography 0.8.3Requirements are unchanged.
Re: Biography Reply #28 – 2017-08-24 15:41:06 New Version: JScript Biography 0.8.4Requirements are unchanged.
Re: Biography Reply #29 – 2017-08-24 19:11:43 New Version: JScript Biography 0.8.4.1Requirements are unchanged. Last Edit: 2017-08-24 19:20:40 by WilB
Re: Biography Reply #30 – 2017-08-27 16:35:27 New Version: JScript Biography 0.8.4.2Requirements are unchanged.
Re: Biography Reply #31 – 2017-09-05 17:55:13 New Version: JScript Biography 0.8.5Requirements are unchanged. Last Edit: 2017-09-05 18:35:08 by WilB
Re: Biography Reply #32 – 2017-09-09 19:04:13 New Version: JScript Biography 0.8.5.1Requirements are unchanged.
Re: Biography Reply #33 – 2017-10-05 19:11:22 New Version: JScript Biography 0.8.5.2Requires JScript Panel 1.3.0+ for full functionality. Will work with JScript Panel 1.1.0+ except tag writing won't be available.
Re: Biography Reply #34 – 2018-01-24 18:02:24 ^^^ Note that JScript Biography 0.8.5.2 and earlier versions won't work with JScript panel v2+.
Re: Biography Reply #35 – 2018-01-24 18:19:28 New Version: JScript Biography 0.9REQUIREMENT: JScript panel 2.01+Existing users: If updating from v0.8.5.1 or v0.8.5.2, you just need to install v0.9. If updating from v0.8 to v0.8.5, to retain settings, install 0.8.5.2 first and before updating JScript Panel to v2+.
Re: Biography Reply #36 – 2018-01-27 17:35:03 New Version: JScript Biography 0.9.0.1REQUIREMENT: JScript panel 2.0.1+
Re: Biography Reply #37 – 2018-01-28 10:09:08 Hello WilB! I get this error when trying to install JScript panel 2.0.1+ https://frupic.frubar.net/shots/36392.jpgJScript panel 1.3.2.2 and JScript Biography 0.8.5.2 works just fine. Using foobar2000 v1.3.17More info:Also tried "DarkOne v4.0 - Tedgo - JScript Biography Version (0.9.01) - Modified by WilB.fcl"and get this error:https://frupic.frubar.net/shots/36393.pngWhat can I do?Best regards Last Edit: 2018-01-28 10:27:30 by redorb
Re: Biography Reply #38 – 2018-01-28 15:31:47 JScript Panel 2 requires foobar2000 1.4 (currently beta) and above.
Re: Biography Reply #39 – 2018-01-29 00:18:11 How did you force that? Just so anyone knows, the current SDK defaults to only requiring 1.3 or newer.
Re: Biography Reply #40 – 2018-01-29 00:46:55 JScript panel is used to run it, and that now requires foobar2000 1.4. You would need to get an answer from marc2k3 as to how and why he did it, as JScript panel is his plug-in. Last Edit: 2018-01-29 00:56:48 by WilB
Re: Biography Reply #41 – 2018-01-29 03:11:04 Quote from: kode54 on 2018-01-29 00:18:11How did you force that?It's in marc2k3's changelog. I believe he did it because he's making a lot of breaking changes.
Re: Biography Reply #42 – 2018-01-29 09:43:46 Quote from: Jailhouse on 2018-01-28 15:31:47JScript Panel 2 requires foobar2000 1.4 (currently beta) and above.OK, that explains it. I'll probably wait for a stable realease of foobar2000.
Re: Biography Reply #43 – 2018-01-30 18:39:53 Quote from: redorb on 2018-01-29 09:43:46Quote from: Jailhouse on 2018-01-28 15:31:47JScript Panel 2 requires foobar2000 1.4 (currently beta) and above.OK, that explains it. I'll probably wait for a stable realease of foobar2000.DarkOne v4.0 only works with JScript Panel 1.3.0+All Scripts have to be updated for newer JScript Panel Versions. But I have nothing heard from Tedgo for about a year...
Re: Biography Reply #44 – 2018-01-31 15:59:50 QuoteDarkOne v4.0 only works with JScript Panel 1.3.0+All Scripts have to be updated for newer JScript Panel Versions. But I have nothing heard from Tedgo for about a year...Do you mean DarkOne v4.0 won't work with foobar2000 1.4 and JScript Panel 2 and WilB JScript Biography 0.9.0.1? Last Edit: 2018-01-31 16:02:55 by redorb
Re: Biography Reply #45 – 2018-02-01 05:06:54 Quote from: redorb on 2018-01-31 15:59:50QuoteDarkOne v4.0 only works with JScript Panel 1.3.0+All Scripts have to be updated for newer JScript Panel Versions. But I have nothing heard from Tedgo for about a year...Do you mean DarkOne v4.0 won't work with foobar2000 1.4 and JScript Panel 2 and WilB JScript Biography 0.9.0.1? Sorry, meant DarkOne4Mod. It uses JScript Panel for several UI Elements. But the Scripts were not actualized for a long timeThe older v4 uses WSH Panel Mod for those UI Elements. JScript Biography 0.9.0.1 seems to work.
Re: Biography Reply #46 – 2018-02-01 09:47:34 QuoteSorry, meant DarkOne4Mod. It uses JScript Panel for several UI Elements. But the Scripts were not actualized for a long timeThe older v4 uses WSH Panel Mod for those UI Elements. JScript Biography 0.9.0.1 seems to work. Ok, great! Thanks for the clarification! Got a bit worried 'cause I just love DarkOne v4! Best regards
Re: Biography Reply #47 – 2018-02-05 19:27:21 New Version: JScript Biography 0.9.0.2REQUIREMENT: JScript panel 2.0.1+ Last Edit: 2018-02-05 19:36:35 by WilB
Re: Biography Reply #48 – 2018-03-02 09:06:34 Hi...is it possible to auto cylce artist bio und pics only for the current track (feat. Artist or the Solist, Orchestra etc.) and not between similar artist???Thanks!LG Frank
Re: Biography Reply #49 – 2018-03-02 13:45:17 Right click > sources > server settings. Opens biography.ini. Set the number of similar artists to display to 0 as shown below:[ADVANCED: MORE MENU ITEMS]......Similar Artists: Number to Display(0-10)=0Save biography.ini & restart foobar2000.It should then auto-cycle bios and pics for tag items of the current track; e.g. artist, composer and performer, including items in multi-value fields, etc.HTH Last Edit: 2018-03-02 14:04:09 by WilB
