Topic: Vinyl Ripping Workflow Suggestions Appreciated (Read 15130 times) previous topic - next topic
Re: Vinyl Ripping Workflow Suggestions Appreciated
Why is the focus on simulations of analog filters?
For me this was about whether post-processing needs to include ultrasonic frequencies and whether there is a need to keep a master that includes ultrasonic frequencies.  I made no requirement that content must be filtered in the analog domain prior to digitization.
My plots are just showing the output difference of few different implementations of a digital biquad LP IIR filter and the analog prototype is there because of these IIR filters are usually based on it (s domain TF for LPF: H(s) = 1 / (s^2 + s/Q + 1)) and IIR filters found in a software implementation are usually based on the linked RBJ's paper (biquad or cascaded biquads) or similar approach.
OP seems to have gone, but the best advice I can give is: save the original transfer.
Don't let the only copy you keep be the one that's gone through several stages of processing. You might/will later find fault with that processing.
