Topic: foo_sqlite (Read 17378 times) previous topic - next topic
Re: foo_sqlite
Reply #100
I just reproduced the crash in a clean installation with the stock foo_sqlite.dll. Open foobar, add one playlist more than were there on opening, and query SELECT * FROM Playlist.
I tried the same, but it worked for me without any problems. Also updating PlaylistUpdatable to split values with commas into multiple value works for me without any crash. And I tried several cases with and without your database. Even updating almost 40000 tracks which were all prepared to have a multivalue field containing commas was no problem.
So, there must be an additional parameter in your setup, that causes the crashes.
Re: foo_sqlite
Reply #101
Miscellaneous observation: I got my latest foobar incarnation all tidied up, and I noticed that the zip of it all is quite a bit bigger than the previous one. I did a pretty good job of getting all my cruft out of there, so I looked around for what else was present. It seems that, between SQLite Viewer and Random Pools, I am now the proud owner of two copies of icutd70.dll, and it's a big 'un. I guess that explains it. :D
It's not a big deal, but could I perhaps get away with one?
Re: foo_sqlite
Reply #102
In theory, yes. The DLLs just needs to be placed somewhere in the search path. However I highly recommend not to do anything like that, just to save some MB. The DLLs might be different in the future for both components, just because one component was already upgraded with a newer version, while the other wasn't.
Re: foo_sqlite
Reply #103
I've just run a bunch of my stored programs and with the metadb_handle to path change, they all seem to work…
Help! I'm not finding anything anywhere on what to change metadb_handle to.
Here's a sample query:
INSERT INTO Playlist_Updatable(metadb_handle,playlist_name)
SELECT metadb_handle, "Top 25" FROM MediaLibrary WHERE play_count > 0 ORDER BY play_count DESC LIMIT 25;
What does "the actual file path and subsong index" even mean in this context?
I'm trying to populate the playlist with the top 25 most played songs. So, actual file path to all my music? Subsong index makes no sense here because I want to check all songs…
(It's pretty obvious I don't know why I had to use metadb_handle in the first place, but it just worked, so I never questioned it.)
Processed audio in java and python.
Re: foo_sqlite
Reply #104
Just change it to "path, subsong". So your sample query will become
INSERT INTO Playlist_Updatable(path, subsong, playlist_name)
SELECT path, subsong, "Top 25" FROM MediaLibrary WHERE play_count > 0 ORDER BY play_count DESC LIMIT 25;
They are just two track attributes, which are necessary to uniquely identify a track.
You are misunderstanding the terms file path and subsong here. File path refers to the individual full path of the file belonging to a track and subsong is only relevant, if you have multi-track files, e.g. cue sheets. Then you need the subsong index to refer to a track in this multi-track file.
If you have only single track files, you could omit the subsong, but it is no mistake to always specify it.
It served the same purpose as "path, subsong", but in a more obscure way.
Re: foo_sqlite
Reply #105
Thank you for explaining all that.
Now my error has moved on to 'no such column: Top 25'
Again, no idea why that would happen. That's how I created the playlist Top 25 in the first place. I thought it creates it if it's not there, and updates it if it is there.
Re: foo_sqlite
Reply #106
Yes, of course. I didn't notice it, but you need to put 'Top 25' into single quotes, not double quotes.
Re: foo_sqlite
Reply #107
Again, thank you very much! I've got all my queries working again.
Re: foo_sqlite
Reply #109
error again.
Well, the reports are still for foo_sqlite version 2.1.1, while the latest version is 2.1.4. Nevertheless, the new report shows an additional hint, which could help to fix the issue, as I still don't have any crashes although I use it quite frequently. The dump file shows, of course, where the crash happens, but it's not obvious why it happens there. In addition to the files it would also be helpful which SQL statement exactly you executed.
Besides this, could you please also post the relevant files for version 2.1.4 as I highly doubt, that the issue is fixed with this version?
Re: foo_sqlite
Reply #110
Updated to 2.1.4.
SQL statement:
SELECT count(DISTINCT album) album_count
   FROM medialibrary
Re: foo_sqlite
Reply #111
Updated to 2.1.4.
SQL statement:
   FROM medialibrary
Hmm, according to crash log #127 from today, it must have been a different SQL statement, as "Row limit (5000 rows) for the SQLite console exceeded." was logged to the console right before the crash, while the statement above always returns only one row. So, it would be helpful to get also the crash reports for version 2.1.4.
