I've added them to the table. Mostly they are HDCD-encoded discs that do not use any HDCD features. The Star Wars Soundtrack is a very strange case where there are a handful of completely valid HDCD packets in each track, but it is not fully HDCD, which is interesting, I will look into that. Thanks for the data.
You're welcome. If you update the FFMpeg filter and want me to scan again, let me know, I have fully automated the process.
[Parsed_hdcd_0 @ 0x391e300] The HDCD filter is unlikely to produce a desirable result in this context.
It is the first time I see them, so I am not sure why those warnings appeared.
This is a bug. It is supposed to warn you if there is some resampling or truncation in the stream which might destroy the HDCD code before the filter gets it (or undo the work after), but the warning is false in this case. s16-planar is being converted to s16, which is fine.
If that helps I'm using the following command line:
ffmpeg -hide_banner -nostats -loglevel debug -threads 1 -y -i FILEPATH -af hdcd -f s24le /dev/null
And my custom built FFmpeg is:
ffmpeg version N-81284-g82e53b3 Copyright (c) 2000-2016 the FFmpeg developers
built with gcc 4.8 (Ubuntu 4.8.4-2ubuntu1~14.04.3)
configuration: --prefix=/tmp/ffmpeg.T1kOLSLRjF/FFmpeg --pkg-config-flags=--static --extra-cflags=-I/tmp/ffmpeg.T1kOLSLRjF/FFmpeg/include --extra-ldflags=-L/tmp/ffmpeg.T1kOLSLRjF/FFmpeg/lib --bindir=/opt/ffmpeg/bin --enable-gpl --enable-version3 --enable-nonfree --disable-runtime-cpudetect --disable-ffserver --disable-encoder=vorbis --disable-encoder=aac --enable-x11grab --enable-libfdk-aac --enable-libfontconfig --enable-libfreetype --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxvid --disable-debug --cpu=corei7
libavutil 55. 28.100 / 55. 28.100
libavcodec 57. 51.100 / 57. 51.100
libavformat 57. 46.100 / 57. 46.100
libavdevice 57. 0.102 / 57. 0.102
libavfilter 6. 49.100 / 6. 49.100
libswscale 4. 1.100 / 4. 1.100
libswresample 2. 1.100 / 2. 1.100
libpostproc 54. 0.100 / 54. 0.100
