Topic: Lossy codec with the highest quality (Read 11541 times) previous topic - next topic
lossy codec with the highest quality , who can tell ?
Re: ossy codec with the highest quality
Try starting with Opus at 64 kbit/s. If you notice the difference in sound compared to the original, increase the bitrate to 80. Have a listen again. Tell us, if you notice the difference.
Re: lossy codec with the highest quality
Above the threshold of "transparency", all codecs are equal, maximum quality. That is, for a given piece of audio, if you personally can't tell the difference, then whatever codec and settings you used is as good as lossless.
Therefore you will find our users' listening tests tend to evaluate the performance of codecs at bitrates right around or just below wherever that threshold tends to be. So for example:
http://d.hatena.ne.jp/kamedo2/
https://hydrogenaud.io/index.php/topic,96800.0.html
http://listening-tests.hydrogenaud.io/sebastian/mp3-128-1/results.htm
You may be able to draw some conclusions from those tests, but there is no simple answer. Not every codec or every type of music is evaluated. Your music may not compress as well as the samples used in those tests, or it may compress better. You will have to do your own tests and see what you think.
Not all codecs/encoders archieve transparency at their maximum bitrate or do they?
Every lossy codec that I am aware of will achieve transparency for the vast majority of music at its highest bitrate.
Try VQF  :o  :'(
 :P
There are a few encoders that don't achieve transparency with most music at their highest bitrates,
Examples:
- Built-in wma encoders in ffmpeg.
- VisualOn AAC
- Some really old experimenal/unfinished MP3 encoders.
Try VQF  :o  :'(
 :P
vqf is god!
Maybe somebody else remembers the legendary discussion ;)
Try VQF  :o  :'(
 :P
vqf is god!
I do.
VQF IST GOD WMA IST DEATH KNOW ME NOW !!!!111
Too bad the VQF forum is gone (and I'm not aware of a working archive), otherwise I could link to those fancy ASCII spectrograms again.  ;)
I do feel the need to warn the OP. svanto: the "try VQF" comment is a joke.
Over thinking, over analyzing separates the body from the mind.
Re: Lossy codec with the highest quality
I can't believe I forgot that nonsense. Including my own sad comments, and creating that Agent Smith account just to paraphrase movie quotes. Hmm, I wonder what email address I used for that crap...
Forgot is the operative.  Funny how it worked out. You know, with us being so "closed minded" and all.
