Topic: An Error occur while converting flac file to apple lossless on WinXP/Win7(32bit) (Read 1827 times) previous topic - next topic
1.3.3-1.3.10 bug.
1 out of 1 tracks converted with major problems.
Source: "D:\001\BoA - Only One.flac"
  An error occurred while writing to file (The encoder has terminated prematurely with code 2 (0x00000002); please re-check parameters) : "D:\002\BoA - Only One.m4a"
  Additional information:
  Encoder stream format: 44100Hz / 2ch / 16bps
  Command line: "C:\Program Files\foobar2000\cliexe\qaac.exe" --ignorelength -s --no-optimize --alac -o "BoA - Only One.m4a" -
  Working folder: D:\002\
  Conversion failed: The encoder has terminated prematurely with code 2 (0x00000002); please re-check parameters
But on Win7 64bit, fb2k(convert) is Fine!
Re: An Error occur while converting flac file to apple lossless on WinXP/Win7(32bit)
You don't have iTunes installed or the required dll files extracted into the qaac.exe's location.
thanks Case, it's ok after itunes installed.
