Topic: is there a device which can convert 2 entries into 1 entry ? (Read 1384 times) previous topic - next topic
    I've got a Speaker(amp) which have one audio entry (jack) ...
    I'd like to put 2 output in it (tv and hifi) ...
    Should I make a simple Y cable ? Or can I bought a device which accept 2 entry and convert signal into one ?
    I don't want a switch ... I would like to have a device which could take the current playing line, or both (if both are playing) ...
    Is this kind of device exists ? where could I buy it ?
    Don't want an audio/pro system ... Just want the simplest/cheapest thing ...
    Thanks in advance
Re: is there a device which can convert 2 entries into 1 entry ?
What you want is a mixer.  A passive one should work just fine.
If the output impedances of your source devices are each high enough, you could get away with a Y cable, but I wouldn't recommend doing something that crude.
do you have got a link ? to see what it looks like ?
