Topic: Making MKV files from DVDs (Read 3498 times) previous topic - next topic
Can I make one mkv file with 2 or more DVD titles?
Re: Making MKV files from DVDs
Many things are possible (no idea about players that support those), some reading
http://mod16.org/hurfdurf/?p=8
That didn't help! I want to save more videos in one mkv file with multiple titles that play one after another but aren't same video like on DVD. Is that possible?
something like playlist with all video files combined into one file
MKVToolnix will do what you want. It allows both add and append options. Particularly if you use add option, your issue will be stream selection which will be player dependent.
that would be good if I could somehow link video track with audio track to go along with it
ok. I'll stick with playlists then.
Many things can do this. A quick Google search would've resulted in a lot of information too. Maybe try that before giving up because you didn't get the response you hoped for on one forum.
until I find out a better solution I'll use playlist. thank you all for replays!
