Topic: CueTools Output Naming Template | Incremental Folder Names (Read 2457 times) previous topic - next topic
Hi everyone
I need your help, please. I am struggling to configure the correct CueTools naming template for batch conversions where multiple albums reside in the same folder, named, let's say, "Folder X". Note that these albums (with cue files, all), are not nested in subfolders of "Folder X". What I wish to achieve during the batch conversion, is that the output of each of these conversions goes into its own newly created folder, incrementally numbered, for example, "New Folder 1", "New Folder 2", "New Folder 3", and so forth.
This is the closest I could get, but for some reason the new folders are not numbered incrementally:
[%directoryname%\]new[%unique%]\%filename%.cue
This is another forum topic of seemingly the same dilemma: https://hydrogenaud.io/index.php/topic,101047.msg835291.html#msg835291
Thank you for you assistance.
Re: CueTools Output Naming Template | Incremental Folder Names
for new[%unique%]\%filename%.cue, %unique% is replaced by a number starting from 1 and will increment by 1 unless/until the output path is unique. So if %filename%.cue is already unique then %unique% would not get replaced by a number.
I don't think you can do what you want with the template tools available. Perhaps %album%[ %unique%], %artist%-%album%[ %unique%] or %filename%[ %unique%] instead of new[%unique%]
korth
I thank you very much, Korth. I am going to play around some with the naming string you have suggested.
Just a note. I used [ %unique%] in the examples in case a cue is processed more than once. This creates a new folder instead of attempting to overwrite the existing files.
korth
Thanks, that is how I understood it. I have yet to do some conversions applying your suggested template, but it looks like it will do exactly what I needed it for.
As an experiment, I have so far converted a single album several times- each time applying a different naming syntax of those proposed by Korth. What struck me is that if I apply %album%[ %unique%], %artist%-%album%[ %unique%] or %filename%[ %unique%] instead of new[%unique%], the ensuing folder names now nesting in an already long folder name, may create a path length longer than allowed by Windows.
If having trouble with the path length you can convert to a different location then (if necessary) move the folders later to the desired location:
C:\music\converted\%artist%\%album%[' ('%unique%')']\%filename%.cue
C:\music\converted\%artist%\%album%[' ('%unique%')']\%artist% - %album%.cue
C:\music\converted\%filename%[' ('%unique%')']\%filename%.cue
korth
Thanks, Korth, I lost sight of that possibility altogether. Otherwise, I have so far completed numerous batch conversions, and they have all gone splendidly using this syntax: [%directoryname%\]%album%[%unique%]\%filename%.cue.
