Topic: Show artwork in parent folder (Read 1509 times) previous topic - next topic
Hi guys.
Let's say I have this folder structure
- FOLDER A
- - FOLDER B
- - - Tracks.mp3
So, I want Foobar to take the artwork not from the Folder B, but from its parent folder, folder A. I have Artwork.jpg there.
The only workaround I see is to attach the image to every mp3s in those folders and I don't want to do that. There's another one and it's even worse: copy the Artwork.jpg in every folder.
So, is there a way to trick Foobar into doing this?
Re: Show artwork in parent folder
File>Preferences>Display>Album art>TYPE
I use the following to display the cover in sub-folders:
^That's just plain wrong. First of all, a sub folder is contained within the same folder as the music file so you'd use
And increasing the number of periods does nothing. If you want to go further up the folder structure, you'd use
ahahaha
So I already tried that, the thing is, I tried it with the other slash ( / )
Thanks guys (is there a way to "overwrite" the artwork that is already in the mp3? I guess I need to delete every one)
File>Preferences>Advanced>Display>Album art>Embedded art vs external>Prefer external
If you want to remove embedded art, foobar can do it from multiple tracks at once. Just select them all>right click>Tagging>Remove all pictures.
thanks so much, i love you marc i'll give you my babies next time i see you around
My folder structure is like this:
If I enter
or
foobar does not display any artwork.
If I enter
foobar displays the artwork.
Then explain to me why my
work but the code you posted does not work for me?
for ..\..\folder.jpg to work there obviously must be a folder.jpg existing in the grandparent folder. If there ain't one it won't do anything...
