Topic: Hmm, having some trouble (Read 2051 times) previous topic - next topic
OKay, i recently downloaded n album from some1 n when i unzipped it, it came with a .cue file (very small) n then i have the big file which is .ape, should i get an .ape decoder, or player, or should I just rename the file to .bin in try to burn it in a .bin/.cue program. ???
ne help would be greatly appreciated
Thanks Much,
Addison
Get the .ape plugin for your favorite player and use that in conjunction with the cue file.
The cue file tells you where the tracks begin and end.  The ape file is a lossless compression of an entire album (or so I'm guessing).
I think you can get more information at monkey audio
You should decompress the file using Monkey's to a wave. Foobar will decompress it too. Foobar does a great job. My guess is to burn it using Exact Audio Copy as it is usuall used when ape and cue are involved. Probably, using another cd copying program to burn will make a mess.
AMD T-Bird 1400
Abit KT7A Raid
2 WD 40g @ 7200rpm raid 0
1 Maxtor 30g @7200rpm
1.5gb pc133
GeForce FX-5200
Creative Audigy 2
Cendyne 24x10x40 cdrw
Toshiba DVD 16X
Thermalright AX7
I thought EAC burns cue/ape just fine.
