Topic: Comparing EAC logs (Read 431 times) previous topic - next topic
Comparing EAC logs
What is the way to check if a pirated CD's log that I came by on the net belongs to my own rip that I did a long time ago if it is edited?
Re: Comparing EAC logs
If the log has a hash code at the bottom, you can verify it with EAC's tool. If the tool says it's OK then that would nullify your suspicion.
Otherwise you should consider whether your disc and ripping parameters are all that special. Even if so then please also consider that forum policy frowns on the illegal distribution of copyrighted material and the tolerance regarding the who, where and how of these activities is very low.
