Topic: callback for timecode? (Read 796 times) previous topic - next topic
Hello,
the callback virtual void FB2KAPI on_playback_time(double p_time) = 0; in play_callback.h
is every second. Is there also a callback every 10 or 100 Milliseconds? I want to build a Timecode output.
Günter
Re: callback for timecode?
The callback as you've noticed ticks at 1Hz and there is not any alternative to my knowledge.
In my foo_wave_seekbar component I poll the playback position on a WM_TIMER message as I draw at a particular rate anyway.
static_api_ptr_t<playback_control> pc;
double t = pc->playback_get_position();
It's worth noting that the times you get from the playback callback and the times you get from playback_get_position are not quite in sync, if you gather information from both you'll get hitches every second so I recommend only using one of the alternatives.
Hello Zao,
thank you for your help!!!
Whats the lag of your Timer?
Edit: Is playback_get_position only in seconds???
Quote:
virtual double    playback_get_position ()=0
Returns current playback position within currently played track, in seconds.
I have installed your seekbar and it works fine. It is possible to start (or better pause) a stopped only by clicking on the waveform (set the cursor)?
Günter
Hello marc2003,
thank for your help!
So i try to write a component which calls playback_get_position every 10 milliseconds and write the value to an serial Port.
2 decimal places are enough..
regards,
Günter
Hello Zao,
how did you get access to the WMTimer?
I cant start the Timer...
Günter
Hello,
the timer is running. But it has an Jitter when the song is played.
class myinitquit : public initquit {
public:
void on_init() {
console::print("Sample component: on_init()");
a.connect();
HWND w = core_api::get_main_window();
SetTimer(w, 12, 100, (TIMERPROC)&winproc);
static LRESULT CALLBACK winproc(HWND wnd, UINT msg, WPARAM wp, LPARAM lp)
switch (msg)
case WM_TIMER:
if (wp == 12)
unsigned long long t = abs(pc->playback_get_position()*10);
a.send(t);
break;
case WM_DESTROY:
return 0;
return uDefWindowProc(wnd, msg, wp, lp);
Hello,
now i used the callback: virtual void FB2KAPI on_playback_time(double p_time) = 0;
This is also very unaccurate...
There is no callback at 0 Seconds.
Günter
Wellcome to my Timeblog.
void on_playback_starting(play_control::t_track_command p_command, bool p_paused) {
ComPort.send(0);
void on_playback_time(double p_time) {
unsigned long long t = (unsigned long long)abs(p_time);
if (t == 1)ComPort.send(t);
The time between playback_starting and the first on_playback_time tick is between 1,2 and 1,4 Seconds. :o
Time between release of the Playbutton (measured at the left Mouseswitch) , the on_playback_starting callback to an Comport is only 10-20 Milliseconds. :)
Hello,
on_playback_time
on_playback_seek
works fine
on_playback_pause
on_playback_stop
on_volume_change
nothing happens
is something wrong with my code?
class play_callback_changes : public play_callback_static
void on_playback_new_track(metadb_handle_ptr p_track) {
void on_playback_stop(play_control::t_stop_reason p_reason) {
ComPort.send(1);//no event
void on_playback_dynamic_info_track(const file_info & p_info) {
void on_playback_edited(metadb_handle_ptr p_track) {
ComPort.send(2);//OK
//unsigned long long t = (unsigned long long)abs(p_time*100);
ComPort.send(3);//OK
void on_playback_seek(double p_time) {
ComPort.send(4);//OK
void on_playback_pause(bool p_state) {
ComPort.send(5);//no event
void on_playback_dynamic_info(const file_info & p_info) {
void on_volume_change(float p_new_val) {
ComPort.send(6);//no event
unsigned int get_flags() {
return flag_on_playback_new_track
| flag_on_playback_edited
| flag_on_playback_starting
| flag_on_playback_seek
| flag_on_playback_time
static play_callback_static_factory_t<play_callback_changes> g_play_callback_changes;
Check your get_flags() ??
yes, the flags will help!  :D
So i will poll playback_get_position with a wm_timer all 10 ms to get the nearest startpoint of the soundfile. This startpoint go to an external mikrocontroller which generates the Miditimecode from an accurate clock, On_playback_pause and on_playback_stop will also set the external clock.
thanks for the help!
Günter
