Topic: Library Tree Discussion (Read 53621 times) previous topic - next topic
Re: Library Tree Discussion
Reply #300
You really shouldn't bother with a JSP version. As mentioned a few posts up, newer versions of JSP require windows 7 just like SMP so all users of your scripts should be on SMP by now. Even the Georgia theme has a SMP version now (currently beta but should be released fully soon).
Reply #301
Just had this script crash (see below). I'm using 1.4.2 of SMP.
Error: Spider Monkey Panel v1.4.2-dev+5fa2496a (Library Tree: Library Tree v2.1.3 by WilB)
lib.node[v] is undefined
File: Library Tree 2.1.3.js
Line: 1635, Column: 11
Stack trace:
  Populate/this.buildTree/</<@Library Tree 2.1.3.js:1635:11
  Populate/this.buildTree/<@Library Tree 2.1.3.js:1634:23
  Populate/this.buildTree@Library Tree 2.1.3.js:1628:12
  Populate/this.buildTree/<@Library Tree 2.1.3.js:1647:42
  Populate/this.branch@Library Tree 2.1.3.js:1570:14
  expandCollapse@Library Tree 2.1.3.js:2012:10
  Populate/this.lbtn_dn@Library Tree 2.1.3.js:2049:26
  on_mouse_lbtn_down@Library Tree 2.1.3.js:2889:192
Reply #302
I wasn't able to reproduce the issue. You can try replacing lines 1632-1639 with the following, which ought to fix it.
switch (true) {
case l != -1 && !showTracks:
range(item.item).some(v => {
if (lib.node[v] && (lib.node[v].length == l + 1 || lib.node[v].length == l + 2)) return item.track = true;
break;
case l == 0 && lib.node[item.item[0].start] && lib.node[item.item[0].start].length == 1: item.track = true; break;
Else the fix will be in the next version.
Thanks for reporting.
Reply #303
Not sure if it's feasible, but a reverse sorting function specifically for the date field would be nice. I wish to be able to sort albums chronologically in order of newest to oldest.
Reply #304
You can use $nodisplay:
$nodisplay{X} Sorts & groups by X without display of X
For example, the following sorts latest albums first & displays the date.
%artist%|$nodisplay{$sub(99999,%date%)}%album%[ '['%date%']']|%tracknumber%. %title%
The next version has embedded extended syntax help + a proper manager for views & filters, so doing things like this should be easier. It should also satisfy requests for integrated thumbnail support and is planned to include an optional 2 panel mode...
Reply #305
Thanks very much! I wasn't aware of such a syntax. Looking forward to the next version.
