Topic: YouTube Track Manager Discussion (Read 22245 times) previous topic - next topic
Re: YouTube Track Manager Discussion
Reply #100
You can try replacing the problematical line (3415) with the following:
if (!cur_handle || !cur_handle.Compare(handle) || image && cov.cacheHit(i_x, image_path)) return;
Reply #101
Is there a way to store all found radio tracks (e.g. search result 'iSelect Radio - 163 Tracks') directly and in total in a playlist? Selecting Options -> Save Playlists -> RadioTracks just adds the played tracks to the newly created playlist, and the playlist 'Radio' lists max 25 of the total found tracks.
I sometimes would like to do some manual adaptions to the identified tracks.
Reply #102
Try the 'iSelect / Save Soft Playlists' option if you're using the library 'iSelect' mode. You can then play directly from the playlists. For the standard last.fm radio modes, full lists aren't created up front. It's a dynamic load and the next track is searched for on load, obtaining more data from last.fm as and when required.
Reply #103
Great, thanks!
...now I do not really understand how I have overseen the Soft Playlists option...
Reply #104
fb 1.6.4, SMP1.4.1, YTTM 1.4.3
YTTM on SMP crashes when search for similar song is done using pipe separator ('|') as necessary to separate artist and title. Omitting pipe separator is stable (however - of course - does not lead to the indended search result...).
Can anybody help here?
invalid array length
File: YouTube Track Manager.js
Line: 10, Column: 65
Stack trace:
  take@YouTube Track Manager.js:10:65
  Lfm_radio_tracks_search/this.Analyse@YouTube Track Manager.js:1153:34
  Lfm_radio_tracks_search/this.on_state_change@YouTube Track Manager.js:1056:50
  do_lfm_lib_radio_tracks_search/lfm_lib_search<@YouTube Track Manager.js:2405:81
YouTube Track Manager.js line 10:
take : (arr, ln) => {if (ln >= arr.length) return arr; else arr.length = ln > 0 ? ln : 0; return arr;},
Reply #105
Please confirm exactly where you are entering artist | title, i.e.
1) Search box near top of YTTM
2) Menu: New Radio > Search for Similar Songs
3) Shift+menu: choose > song lookup... (least likely)
Also please provide some artist | title combinations that give the error. Hopefully I'll then be able to reproduce the issue.
Reply #106
Did some more research on it:
- only talking about your option 2: New Radio -> Search for Similar Song
- for your Opion 1 (Search box near top of YTTM) no crashes appear
- Crashes can be switched on and off with the property
  " SYSTEM.Radio Range"
   If set to '0', New Radio -> Search for Similar Song (incl pipe separator) leads (on my side) to a 100% crash, if set to 1, no crash appears (100%)
  Not really sure what 'Radio Range' exactly does...
- search string does not matter as long it contains a pipe separator, for example ZZ Top | Tush
Hope you can reproduce...
Reply #107
" SYSTEM.Radio Range 0" is same as setting 'new radio > tracks > highly popular'
The next version has some interface improvements which should improve clarity.
The issue ought to be fixed by changing line 2088 as follows.
From
return range;
To
return Math.floor(range);
The fix will be in the next version.
Thanks for reporting.
Reply #108
Fix solves issue!
Great, thanks very much for that immediate help! Looking forward to the next update of this great plug-in.
